Because Remco called me about this forgotten project, I decided to port the original Arduino Pro Mini code to native ESP.
Currently it's only basic time display because the original fastled library was not available for ESP platform and it needs some more work to adapt. But I've managed to switch the bare basics to Adafruit Neopixel library and it's working again.
So now we have a Wifi Wordclock using 114 Neopixel LED's (WS2812) that retrieves the current time from the internet using NTP.
Ok, it's in dutch, but I think you get the message (or time)...
(But I have to be honest, I only took the picture , most of the work is done by Remco and John )
ESP8266 based WordClock
Re: ESP8266 based WordClock
... christmas is coming
How can "i" modify your script that we send with mqtt or/and http different sequences to a ring or stripe (WS2812)
maybe
on/off, brightness, color, rainbow ...
Who can help?
maybe
Who can help?
Hi !
Just working on a RGB WLAN Lamp based on ESPEasy. And it uses also WS2812 stripes ...
I think there is a lot of code you can reuse
But need to finish it - hopefully at weekend ...
regards
Dominik
Dominik
great !moelski wrote:Hi !
I start to fed up of mine.
did you implant some effect ? fire2000 is a good one !
regards
Dominik
Dominik
