Is there any internal solution to control a single channel relay board with ESPEasy?
Setup:
- ESP-01 (black)
-- GPIO-1: DS18B20
-- GPIO-2: Relay board
Eample:
If the temp. value goes above 25c the relay will be OFF state, but if the temp. value goes bellow 21c then the relay will be ON state.
Some example would be appreciated!
Thank you!
[SOLVED] Controlling Relay from ESPEasy directly?
Re: Controlling Relay from ESPEasy directly?
Never did it but should be working with simple EVENT RULE:
on Sensor#temperature>25 do
gpio,2,0
on Sensor#temperature<21 do
gpio,2,1
Thank you, but how can I add EVENT RULES? Didn't find any documentation for it!papperone wrote:Never did it but should be working with simple EVENT RULE:
on Sensor#temperature>25 do gpio,2,0 endon on Sensor#temperature<21 do gpio,2,1 endon
Tools --> Advanced --> enable "Rules" checkmark
Thank you!papperone wrote:Tools --> Advanced --> enable "Rules" checkmark
It's so hidden and luck of documentation (didn't find anything regarding on the WIKI)!
