this evening I finished my Wifi Candle based on ESPEasy. This was a long term project of mine but I never had the time to get it done.
But now I think it´s mostly finished. Have to build the hardware into the housing but the coding part is ready
The lampe based on the adafruit Neopixel lib. The code is at some parts inspired by some web templates.
The hardware is only a NodeMCU with 20 WS2812 Pixels in a 4*5 Matrix. Take a look at the picture ...
And I use some paper for a light diffusor.
The rest is some coding (~700 lines of Code) and the great work of the ESPEasy devs
To make this working I had to tweak the ESPEasy code a little bit. Default there is only a 100ms timer but that is way to slow to drive the candle smoothly.
So i added another timer with 25ms cycle time. This give great results.
I added a first video to my webspace:
http://www.logview.info/Temp/WifiCandle.mp4
You can find the Code in the ESPEasy Playground:
https://github.com/ESP8266nu/ESPEasyPluginPlayground
And I have written some Setup notes for the candle:
http://www.logview.info/Temp/CandleNotes.pdf
