one-ESP node command does not work
To make a long story short, I've made a few pics to show my problem to the community !
Thanks for any hint ....
Re: one-ESP node command does not work
Did you do a reboot ?
Nescessary to make the nodelist and UDP work.
Yes of course, I rebooted right after setup (2) so to make sure the node list and setup are refreshed ...costo wrote:Did you do a reboot ?
Actually, I am wondering whether sending a 'command' via the 'tools' menu ***ONLY*** works on other EPSs in the node list and ***NOT*** on oneself ???
In the wiki it says "SendTo" while you have "sendto".
Did you try whether the command is case sensitive?
The rules section also uses case-sensitive commands.
No way, it makes no difference, my LED 's still dumb !!!hvdwolf wrote:In the wiki it says "SendTo" while you have "sendto".
I did not try but could make sense, why you should send a command to the same node you sent it from?ym58 wrote:Yes of course, I rebooted right after setup (2) so to make sure the node list and setup are refreshed ...costo wrote:Did you do a reboot ?
out of consistency !papperone wrote:I did not try but could make sense, why you should send a command to the same node you sent it from?ym58 wrote:Yes of course, I rebooted right after setup (2) so to make sure the node list and setup are refreshed ...costo wrote:Did you do a reboot ?
a node is a node, no matter what ...
You are very stubborn. First read the wiki (http://www.letscontrolit.com/wiki/index ... rial_Rules) and then search this forum. You can't send a message to yourself.
I had not looked at that as I could not imagine you would try that.
Edit: As far as I know the UDP protocol does not even allow that.
"Very stubborn" ... ?hvdwolf wrote:You are very stubborn. First read the wiki (http://www.letscontrolit.com/wiki/index ... rial_Rules) and then search this forum. You can't send a message to yourself.
Well, let's just say that I was looking for a simple kinda 'GUI-like' way to send commands to my ESP module that would spare me typing URLs such as http://192.168.11.110/control?cmd=gpio,13,0 in the address bar of my browser!
Sorry about the 'disturbance' ...
I have been looking into the code and indeed I think it's like that both by design and probably by used protocol limit (UDP).ym58 wrote:"Very stubborn" ... ?hvdwolf wrote:You are very stubborn. First read the wiki (http://www.letscontrolit.com/wiki/index ... rial_Rules) and then search this forum. You can't send a message to yourself.
I'm not sure what you want to achieve but if you need to send command to the same node from it's own ESPEasy GUI then just type it! Use "gpio,13,0" instead of "SendTo 1,gpio,13,0", it works smooth and perfectly
Gosh ... how could I have missed that ?papperone wrote:I have been looking into the code and indeed I think it's like that both by design and probably by used protocol limit (UDP).
I think I am ***REALLY*** more stupid than stubborn, actually !
Thanks papperone for this constructive advice ...
Users browsing this forum: No registered users and 26 guests
