- debug on serial port must be deactivated.
This code is modified my beta PCD8544 plugin. It can only send SMS - its dirty but maybe some one can make it better
![Lach :)](./images/smilies/icon_e_smile.gif)
Important - only real ASCII character can be used.
//#################################### Plugin 210: GSM MODEM - TC35 #################################
// Sample templates
// Temp: [DHT11#Temperature] Hum:[DHT11#humidity]
// DS Temp:[Dallas1#Temperature#R]
// Lux:[Lux#Lux#R]
// Baro:[Baro#Pressure#R]
#define PLUGIN_210
#define PLUGIN_ID_210 210
#define PLUGIN_NAME_210 "GSM MODEM - TC35"
#define PLUGIN_VALUENAME1_210 "TC35"
boolean sendSMS = false;
byte ResetPin = 0;
boolean Plugin_210(byte function, struct EventStruct *event, String& string)
boolean success = false;
static byte displayTimer = 0;
switch (function)
case PLUGIN_DEVICE_ADD:
Device[++deviceCount].Number = PLUGIN_ID_210;
Device[deviceCount].Type = DEVICE_TYPE_SINGLE;
Device[deviceCount].VType = SENSOR_TYPE_SINGLE;
Device[deviceCount].ValueCount = 0;
Device[deviceCount].SendDataOption = false;
case PLUGIN_GET_DEVICENAME:
string = F(PLUGIN_NAME_210);
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_210));
case PLUGIN_WEBFORM_LOAD:
char deviceTemplate[6][64];
LoadCustomTaskSettings(event->TaskIndex, (byte*)&deviceTemplate, sizeof(deviceTemplate));
for (byte varNr = 0; varNr < 6; varNr++)
string += F("<TR><TD>Line ");
string += varNr + 1;
string += F(":<TD><input type='text' size='64' maxlength='64' name='Plugin_210_template");
string += F("' value='");
string += deviceTemplate[varNr];
string += F("'>");
//string += F("<TR><TD>Display button:<TD>");
//addPinSelect(false, string, "taskdevicepin3", Settings.TaskDevicePin3[event->TaskIndex]);
char tmpString[64];
sprintf_P(tmpString, PSTR("<TR><TD>Display Timeout:<TD><input type='text' name='plugin_210_timer' value='%u'>"), Settings.TaskDevicePluginConfig[event->TaskIndex][2]);
string += tmpString;
success = true;
case PLUGIN_WEBFORM_SAVE:
String plugin3 = WebServer.arg("plugin_210_timer");
Settings.TaskDevicePluginConfig[event->TaskIndex][2] = plugin3.toInt();
char argc[25];
String arg = F("Plugin_210_template");
arg += varNr + 1;
arg.toCharArray(argc, 25);
String tmpString = WebServer.arg(argc);
strncpy(deviceTemplate[varNr], tmpString.c_str(), sizeof(deviceTemplate[varNr]));
Settings.TaskDeviceID[event->TaskIndex] = 1; // temp fix, needs a dummy value
success = true;
case PLUGIN_INIT:
ResetPin = Settings.TaskDevicePin1[event->TaskIndex];
//Plugin_210_reset_modem();
pinMode(ResetPin, INPUT);
digitalWrite(ResetPin, LOW);
pinMode(ResetPin, OUTPUT);
delay (500);
digitalWrite(ResetPin, HIGH);
delay (3000);
Serial.println("AT+CMGF=1");
delay(500);
success = true;
case PLUGIN_TEN_PER_SECOND:
if (Settings.TaskDevicePin3[event->TaskIndex] != -1)
if (!digitalRead(Settings.TaskDevicePin1[event->TaskIndex]))
displayTimer = Settings.TaskDevicePluginConfig[event->TaskIndex][2];
case PLUGIN_ONCE_A_SECOND:
if ( displayTimer > 0)
displayTimer--;
//if (displayTimer == 0)
//Plugin_210_modemOff(); // MODEM OFF
case PLUGIN_READ:
if (sendSMS)
Serial.begin(9600);
for (byte x = 0; x < 6; x++)
String tmpString = deviceTemplate[x];
if (tmpString.startsWith("+"))
lcd->setCursor(0,3);
lcd->print("SendSMS");
tmpString = parseTemplate(tmpString, 14);
int firstmark = tmpString.indexOf('^');
int endmark = tmpString.indexOf('^',firstmark + 1);
String phonenummer = tmpString.substring(0,firstmark);
String smstext = tmpString.substring(firstmark+1, endmark);
delay(500);
String SMSmessage = "AT+CMGS=\"" + phonenummer + "\"\r";
Serial.print(SMSmessage); // Send phonenummer to GSM MODEM
delay(500);
Serial.println(smstext); // Send text to GSM MODEM
Serial.print("\r");
delay(500);
Serial.println((char)26); // ASCII Ctrl-Z
Serial.println();
lcd->setCursor(7,3);
lcd->print(" OK");
delay(2000);
lcd->print(" ");
sendSMS = false;
success = false;
case PLUGIN_WRITE:
String tmpString = string;
if (argIndex)
tmpString = tmpString.substring(0, argIndex);
if (tmpString.equalsIgnoreCase(F("TC35")))
success = true;
argIndex = string.lastIndexOf(',');
tmpString = string.substring(argIndex + 1);
if (tmpString.equalsIgnoreCase(F("TC35CMD")))
success = true;
if (tmpString.equalsIgnoreCase(F("SendSMS")))
Plugin_210_sendSMS();
else if (tmpString.equalsIgnoreCase(F("Reset")))
return success;
void Plugin_210_reset_modem(void)
delay (500);
delay (1000);
void Plugin_210_sendSMS(void)
sendSMS = true;
![Knipoog ;)](./images/smilies/icon_e_wink.gif)
B.R.
Adam
