Is it possible save/restore Device's values before/after reboot?
Same question regarding the switch the electricity?
Device values persistence
- paveleremin
Re: Device values persistence
To be more clear, how to save this values before reload(power off):
- paveleremin
Maybe it's possible add some checkbox for each value, something like "Persistent data" and add some more code to handle it
It will cool feature
I think that it would be useful ! If anybody know...
I think there is a way to use the broker to srore and retrieve values. Using ESPEasy in standalone mode I can't guide you but it may be "MQTT Retain Msg" in advanced settings. Keep in mind that writing to flash memory causes wear and - depending on how often this is done - will brick the device at some point (see the sticky threads). Implementing this locally could be a bad idea.
The feature is there in the mega version.
- paveleremin
Users browsing this forum: No registered users and 124 guests
