[Solved] Factory Reset without WiFi
Elektrofreak
#1 Post by Elektrofreak » 13 Jan 2017, 08:47
I have a problem with the ESPEasy Firmware version 147RC8. I made a wrong config and now the chip does not startup anymore. I already tried re-flashing the firmware ut it loads the old config being stored in the chip (I rarely can ping the chip for some ms within some minutes)
Currently I try to run wget infinitely to call the reset command but it never gets the url...
Is there a possibility to erase the settings to factory reset via serial programming?
PS: This is a little urgent because the heating system is failing and I don't have a spare board (and resoldering a chip is only the last chance). Configs are backed up :-)
Edit: Just to let you know in case you have the same problem: This solved my problem
http://www.esp8266.com/viewtopic.php?p=27517
In my case:
esptool.py --port /dev/ttyUSB1 --baud 1152000 erase_flash
DeNB3rt
Re: [Solved] Factory Reset without WiFi
#2 Post by DeNB3rt » 13 Jan 2017, 15:27
Is that a command you ran in cmd (windows?) :)
Elektrofreak
#3 Post by Elektrofreak » 16 Jan 2017, 07:17
I moved to a raspbian distribution (Raspberry Pi) which had python already installed to get rid of installing it on windows :-). This made it a little easier. But it should work the same way (after installing python) on windows ;)
lets_esp_it
#4 Post by lets_esp_it » 17 Jan 2017, 08:33
How to do it in windows ?
