I have this RFlink gateway:
https://www.nodo-shop.nl/en/rflink-gate ... izing.html
With the firmware R43 it works without problems.
But if I flash a higher version R44 order R45, then the gateway sends and receives nothing more.
What can I do?
Can u help?
BG
Spuckis
Germany
Problems with Firmware > R43
Re: Problems with Firmware > R43
It is due to bad configuration.
You can connect a wire over pins 12 and 13, reboot, remove wire and r45 will work.
The next release will work out of the box without issues.
Users browsing this forum: No registered users and 34 guests
