send commands from one ESP to another
Evening,
I have an ESP measuring several temperatures, another in another place in the house with at the moment an LED to test and later a relay to switch an input on my heating. I can switch the led using
http://192.168.1.205/control?cmd=GPIO,2,0 or 1
from my browser so all good there. Now I want to switch this through a rule in the ESP measuring the temperatures.... I tried all variants from the tutorial http://www.letscontrolit.com/wiki/index ... rial_Rules but can't get it to work.
Any suggestions ??
Thanks !
Any suggestions ??
Thanks !
Re: send commands from one ESP to another
Under advandced tab activate global sync and Set udp Port to the same value on both Devices. Then you can use the sendTo command.
on RFID#Switch=1 do
sendTo 2,pulse,14,1,2000
//timerSet 1,5 //
if [Licht_TH#Lux<10]
gpio,13,1
timerSet 2,30
Ok, done that.
Can see the command being activated from the sending ESP ACT : sendto 243,event, vrijgave
on the receving end however, with the unit set to 243 nothing.. rule in the sender
and in the receiver
on System#Boot do
event,cvaan
on temp_vloer_uit#Temperature_3<25 do
event,cvaan
on temp_vloer_uit#Temperature_3>27 do
event,cvuit
on cvaan do
sendto 243,event,vrijgave
on cvuit do
sendto 243,event,blokkering
and in the receiver
on vrijgave do
GPIO,2,1
on blokkering do
GPIO,2,0
Unit number must be within 0-31.
I prefer SendToHTTP over sendto (TCP vs. UDP). Correct syntax is
SendToHTTP 192.168.1.205,80,/control?cmd=GPIO,2,0
Ok, tried that, same result... nothing
I have both ESP's setup as Domoticz HTTP, ip of the Domoticz server and port 8080... so I changed the command to SendToHTTP 192.168.1.205,8080,/control?cmd=GPIO,2,0
anything wrong there ? I can see again in the log of the sender that it is sending the command aparrently but nothing the reveive ris not getting any commands in by the looks of the log.
And the global sync.. leave it on or off ? Bit lost here![Bedroeft :(](./images/smilies/icon_e_sad.gif)
Also tried the UDP and globalsync roure again, can see both ESP's in the node list. Again, in the sender log can see the command being generarted, receiver log... no joy....
Global Sync is a bit special.
I tested it following http://www.letscontrolit.com/wiki/index ... GlobalSync
for driving a remote LCD display (Sensor on one ESP, display connected to another LCD).
It should be possible to make use of rules to switch a LED / relay from remote values.
If you address an espeasy unit directly you must use the default port for http: 80
It doesn't care what port your broker is listening on.![Knipoog ;)](./images/smilies/icon_e_wink.gif)
Got it to work now with HTTP commandon port 80, thanks !!
Now it keeps sending the command every cycle.. ok but... I would like to change this to somehtin like
and
to make it send only at change of temperature. Would that be possible ??
on System#Boot do
SendToHTTP 192.168.1.205,80,/control?cmd=GPIO,2,1
on vloer_uit#Temperature<25 do
event,cvaan
on vloer_uit#Temperature>27 do
event,cvuit
on cvaan do
on cvuit do
if cvuit=1
event,cvaan
if cvaan=1
event,cvuit
Yes you can, therefore you have to store the state in a dummy device. Or use global sync to take switch state from other unit available. Don't forget to endifyour condition.reddo wrote:Got it to work now with HTTP commandon port 80, thanks !!
Now it keeps sending the command every cycle.. ok but... I would like to change this to somehtin likeCode: Select all
on System#Boot do SendToHTTP 192.168.1.205,80,/control?cmd=GPIO,2,1 endon on vloer_uit#Temperature<25 do event,cvaan endon on vloer_uit#Temperature>27 do event,cvuit endon on cvaan do SendToHTTP 192.168.1.205,80,/control?cmd=GPIO,2,1 endon on cvuit do SendToHTTP 192.168.1.205,80,/control?cmd=GPIO,2,0 endon
andCode: Select all
on vloer_uit#Temperature<25 do if cvuit=1 event,cvaan endon
to make it send only at change of temperature. Would that be possible ??Code: Select all
on vloer_uit#Temperature>27 do if cvaan=1 event,cvuit endon
