is it possible to count pulses from such a kWh s0 meter? I don't mean the led thas flsahing, but the puls that comes from the s0 bus.
I want to be able to monitor 3 strings of SolarPanels in domoticz. Right now i am using an arduino to upload the counting to pvoutput, and then back to domoticz.
s0 kWh meter counter
Re: s0 kWh meter counter
I have a similiar module, just no time to test that yet.
In general:
The output is an "open collector", so it should be no problem to connect the counter to an ESP.
The schematic is easy:
"-" output of the Counter to ground
"+" output of the Counter to a GPIO of your choice.
Remember the "open collector" part: an internal pullup resistor should be activated with the ESP,
or just connect a 3,3 ....10 KOhm Resistor between the GPIO pin the Counter is connected to and 3,3 Volt from the ESP.
In general:
Yes, it works.
S0- to gnd of the ESP, S0+ to the pin, like gpio12.
Can i use espeasy as counter?
Yes that is what I do.
what settings do i need in espeasy to get correct values to domoticz?
The wiki is your friend
