New RFLink firmware (R46) now available!
Information and news about RFLink development and releases
Stuntteam
Site Beheer
#1 Post by Stuntteam » 11 Mar 2017, 00:53
Check here: http://www.nemcon.nl/blog2/
R46: (10/03/2017)
- New Device: Applidom DM82 motion sensor
- New Device: OWL Intuition PV / CM180i
- New Device: WH2A temperature sensors
- New Device: WH1285 TX (WH-5) Temp & Humidity sensor
- New Device: ABB lightswitch type 3299a-11900 (a.k.a. TX Tango) (Receive only!)
- New Device: Velleman VM130T Motor control
- New Device: HRC 101 Motor control
- New Device: AC512-02 AC to RF projection screen trigger
- New Device: 2 new Dooya protocol flavors
- New Device: D-YA / Diya Motor control
- New Device: Konx doorbell model 602 (Receive only!)
- New Device: Doorman doorbell (Receive only!)
- New Device: Acurite 3in1 3N1TXR / 3N1TXC (Thanks: JR)
- New Device: Byron BY532E (Receive only!)
- New Device: Stagnoli remotes
- New Device: Blyss temperature sensors (Ref.630467) (Thanks: JD)
- New Device: Grundig QH-831A 2010525 & Quhwa QH-831A doorbell
- New Device: 868mhz: Woonveilig security sensors
- New Device: 868mhz: Egardia security sensors
- New Device: 868mhz: Alecto WS3900
- New Device: Yale HSA3000/6000 alarm system sensors
- New Device: Sartano 50080 (Harald Nyborg 2794) switch set
- New Device: Astrell 85 portal motorization system
- New Device: Philips AJ7010/12
- New Feature: Learn RF device signals that use a standard EV1527/PT2262 protocol
- Fixed: Some small eeprom handling issues
- Fixed: Improved AI protocol priority handling
- Fixed: various CC2500 issues, make sure pin 6 is wired to ground to use CC2500!
- Fixed: Tightened Warema EWFS detection
- Fixed: RTSlongTX command
- Fixed: ON/OFF vs UP/DOWN command handling
- Fixed: UPM Esic extended packet detection and increased sanity checks on data
- Fixed: Optimized Novatys timing
- Fixed: AlectoV3 Humidity value validation
- Fixed: FineOffset vs Alecto improved differentiation, Note: device ID's have changed for WS1100
- Fixed: Alecto WS-1100 humidity
- Fixed: AlectoV4 Some packets contained an invalid temperature
- Fixed: Globaltronics GT-WT-02 negative temperature/channel number mixup
- Fixed: Globaltronics GT-WT-02 now always reporting a humidity
- Fixed: Tristate send, removed debug message and fixed a timing bug
- Fixed: WS7000 rain reporting
- Fixed: Added additional Brel protocol variant
- Fixed: LightwaveRF turned MOOD commands into regular switch commands so any home automation software can use them
- Fixed: Improved Friedland doorbell signal detection
- Fixed: Acurite 5in1 corrected wind speed, wind direction and rainfall values (Thanks: Xztraz.)
- Fixed: Improved AcuRite 00592TXR detection
- Fixed: Tunex zero humidity value
- Fixed: Improved Home Confort transmit routine and added up/down support (Thanks: Geert)
- Fixed: Battery detection in Prologue protocol
- Fixed: Added channel number to device ID for THGR810
- Fixed: Added channel number support to Warema devices
- Fixed: Improved UPM ESIC protocol detection
- Fixed: Improved SA33 detection
- Fixed: Gaposa protocol timing
- Added: battery status on various Alecto/Maplin devices (Thanks: Ad)
- Added: Hardware & Software configuration via i/o pins:
pin 6 to ground for: CC2500 enable
pin 7 to ground for: disable internal pull-up on RF data in
pin 12 to ground for: reset of EEPROM settings
jjansen
Re: New RFLink firmware (R46) now available!
#2 Post by jjansen » 11 Mar 2017, 09:20
Nice changelog! Thanks, works like a charm :)
rizzo86
#3 Post by rizzo86 » 11 Mar 2017, 15:03
Witch modul use for 868 mhz???
Stuntteam
Site Beheer
#4 Post by Stuntteam » 11 Mar 2017, 15:19
Aurel RTX MID 868 transceiver
Aurel RX-AM8SF receiver
xztraz
#5 Post by xztraz » 11 Mar 2017, 18:29
Awesome! Donated a little bit for all the hard work with the weather sensors.
Stuntteam
Site Beheer
#6 Post by Stuntteam » 11 Mar 2017, 19:46
Tnx!
Redferne
#7 Post by Redferne » 12 Mar 2017, 01:17
Cool. Now FineOffset is FineOffset again, but with an extra 0x30xx added to ID, as a bonus I also got a bunch of outdoor sensors reporting a static 99 humidity 😄
Care to share the secrets behind:
///Redferne
Stuntteam
Site Beheer
#8 Post by Stuntteam » 12 Mar 2017, 09:33
Explanation can be found here:
http://www.nemcon.nl/blog2/faq#RFFind
Gusimelo
#9 Post by Gusimelo » 13 Mar 2017, 22:11
chacon emw200 still doesn't work, nor the CM180i:
144 rfxcom 9800 0 Owl Intuition Energy CM180 4293.700 kWh
3 rfxcom 9800 0 Energia Current Current/Energy CM180i 23 Watt, 23 Watt, 322 Watt, Total: 4293.700 kWh
632 RFLink 00000098 1 OWL_Intuition General kWh 0.000 kWh
633 RFLink 00000198 1 OWL_Intuition General kWh 0.000 kWh
634 RFLink 00000298 1 OWL_Intuition General kWh 0.000 kWh
635 RFLink 00000398 1 OWL_Intuition General kWh 155.048 kWh
Stuntteam
Site Beheer
#10 Post by Stuntteam » 14 Mar 2017, 00:15
Both have been tested and are working.. for the Chacon you need to use the rffind option..
Gusimelo
#11 Post by Gusimelo » 14 Mar 2017, 02:17
Stuntteam wrote: 14 Mar 2017, 00:15 Both have been tested and are working.. for the Chacon you need to use the rffind option..
Well, regarding the cm180i, this is what domoticz gets (RFXCom and RFLink):
144	rfxcom	9800		0	Owl Intuition		Energy		CM180	4295.385 kWh						7	100	2017-03-14 00:55:54
3	rfxcom	9800		0	Energia Current		Current/Energy	CM180i	23 Watt, 23 Watt, 437 Watt, Total: 4295.385 kWh		7	100	2017-03-14 00:55:54
632	RFLink	00000098	1	OWL_Intuition		General		kWh	0.000 kWh						-	-	2017-03-14 00:55:54
633	RFLink	00000198	1	OWL_Intuition		General		kWh	0.000 kWh						-	-	2017-03-14 00:55:54
634	RFLink	00000298	1	OWL_Intuition		General		kWh	0.000 kWh						-	-	2017-03-14 00:55:54
635	RFLink	00000398	1	OWL_Intuition		General		kWh	155.425 kWh						-	-	2017-03-14 00:55:54
For the EMW200 I tried the rffind this way:
turn the rffind mode on; pressed ON/OFFF on domoticz on two switches configured with RFXCom and saved the following:
RF Record: 0 ID: 445557 S: 0E L: 2E T: 01 - ON
RF Record: 1 ID: 445554 S: 0E L: 2E T: 01 - OFF
RF Record: 2 ID: 451557 S: 0E L: 2E T: 01 - ON
RF Record: 3 ID: 451554 S: 0E L: 2E T: 01 - OFF
Now the rflink gets the switches on domoticz as RFCustom, but they don't work... I tried using the remote but get the usual:
10;rffind=on;
20;FD;RFFIND=ON;
20;FE;TriState;ID=045aa2;SWITCH=3;CMD=ON;
20;FF;TriState;ID=08a2aa;SWITCH=2;CMD=OFF;
20;02;TriState;ID=088aaa;SWITCH=2;CMD=OFF;
20;03;TriState;ID=088aaa;SWITCH=2;CMD=ON;
Am I missing something?
TIA
Gustavo Melo
olskar
#12 Post by olskar » 14 Mar 2017, 19:22
Gusimelo wrote: 14 Mar 2017, 02:17
10;rffind=on;
20;FD;RFFIND=ON;
TIA
Gustavo Melo
RFcustom does not work on stable release I think, have to use beta, can that be the problem?
Stuntteam
Site Beheer
#13 Post by Stuntteam » 14 Mar 2017, 19:25
Yes, you for sure need beta..
hw35nl
#14 Post by hw35nl » 14 Mar 2017, 20:02
Hi there
I am pretty new to this but I managed to install r45 with no problems. When I Download r46 there is no RFlink.cpp.hex. Only a RFLinkino.hex. Should I use that.
I use the nodo rflink gateway with nrf.
Regards Harry
Stuntteam
Site Beheer
#15 Post by Stuntteam » 14 Mar 2017, 23:53
Yes, the filename changed and the included loader works fine with it too
Gusimelo
#16 Post by Gusimelo » 15 Mar 2017, 10:39
Stuntteam wrote: 14 Mar 2017, 19:25 Yes, you for sure need beta..
And where can I find the beta?
EDIT: by beta, do you mean domoticz beta?... if so I'm on beta 3.6953
Stuntteam
Site Beheer
#17 Post by Stuntteam » 15 Mar 2017, 10:43
Gusimelo
#18 Post by Gusimelo » 16 Mar 2017, 13:51
I'm running the latest beta, still doesn't work
nordix
#19 Post by nordix » 24 Mar 2017, 01:01
HI,
Since I have upgraded to this version, my Tristate switchs stopped working. I see the frame correctly detected using the remote but sending the same commands has no effect on the switchs . I know that some fix has been added for Tristate protocol but in my case it made my switchs not working anymore.
Anyway, had to roll back to R45 as I am not using the new features brought by R46, but could be usefull if a fix can be provided
Thanks for all the job done on this library!
lassiko
#20 Post by lassiko » 02 Apr 2017, 21:18
Hi. After updating to R46, temp + hum device WTGR800 stopped working. I have two of those together with other type sensors, and only those two are not updating the values. Went back to R45 data started to update again.
Stuntteam
Site Beheer
#21 Post by Stuntteam » 02 Apr 2017, 22:29
WTGR800 is a Domoticz type.. it has no relationship to RFlink other than that it is a temperature sensor..
Possibly the ID has changed in R46.
Make a debug log and mail that to frankzirrone@gmail.com
Users browsing this forum: No registered users and 35 guests
