Send custom packet
Send custom packet
Just a suggestion.
Is it possible to send a custom raw packet on air in a next release ?
I know the right sentence I have to send for a specific device (protocol not known, not supported), but I'm not able to put it on air via rflink. I have not control or method to manage my trx433 on the rflink board.
I must use another rf433 for it on a second board or raspberry.
Via rflink, it should be for example.
10;TxCustomPacket=h200,l400,l400,h200.....;
h high pulse
l low pulse
and length
or save the sentence in epprom
and call it
10;TxCustomPacket=#1;
or something similar
Thanks in advance.
Just a suggestion.
h high pulse
l low pulse
and length
and call it
Thanks in advance.
Re: Send custom packet
check your email..
Did you received my reply by email ?
Maybe, another way should be to have a "Auto Learn Mode" for any raw data packet.
I know there is already the "RfFind" feature, but available only for a couple of protocol known.
The idea should be to grab the raw data packets regardless of the protocol.
Something like 10;AutoLearn=on
Push a button on the remote control.
RFlink should display the packet like RFDebug feature
We could store this packet with ID# and afterwards could replay this packet.
Easy to say as suggestion, but how to do it ?
As far as I know - this is almost impossible to do. You you have already found the solution?
I really like this site
@stuntteam:
You replied by email so I guess it is possible to send custom packets using an undocumented command.
I also needs this feature to send command to a wireless stove management I'm developping.
So is it possible to send custom packets ?
@stuntteam:
No, we do not have fully custom packets. We only have the rffind feature for now.
hi
could you implement something like rcswitch on arduino in rflink because i need to send this
10;Doorbell;ID=1e94;SWITCH=1;CMD=ON;CHIME=01;
20;25;CMD UNKNOWN;
and this not working on rflink but with rcswitch i can ring the bell
with this arduino sketch :
with "101 0001111010010100 00011" middle part 0001111010010100 ----> ID= 1e94
and thanks for sharing and your project.
ps: are answering to your email ? franck....@gmail.com
20;25;CMD UNKNOWN;
#include <RCSwitch.h>
mySwitch.setProtocol(1);
//Optional set pulse length.
mySwitch.setPulseLength(185);
//Optional set number of transmission repetitions.
mySwitch.setRepeatTransmit(3);
//button 3
Serial.println("Envoi Button 3");
mySwitch.send("101000111101001010000011");
