Hello everybody,
I use some 2 ESP-12E node mcu and 2 ESP-12F (minimal version) with ESPEASY. All is fine with this, it'a very good project .
My problem is located on the Blue LED solder on the ESP-12. I can't find a solution to disable totally this LED. I don't want to scratch it, just disable via software.
Blue LED is always ON. I've not this problem if I used a small sketch on the same ESP. I suppose I missed something in the ESPEASY config.
Does anyone has a solution for this. ?
Thx.
ESP-12E/F LED Status.
Re: ESP-12E/F LED Status.
According to this page
http://www.esp8266.com/wiki/doku.php?id ... esp-12-e_q
the LED is on gpio 2, active low.
I've made an erase flash with esptool and upload espeasy again, the led is no more active by default. Quite strange ...
I will try on a second ESP.
