Voilà, I tried with Termite RS232 client and debug mode
I finally succeed with debug mode to detect 433Mhz signal from my remote control used for motorized screen.
Please see 3 sets of codes below.
Do you think it is easy to make RFlink compatible with this protocol ?
Do you need something else ?
I have also a AC trigger that detects power used by projector and sends UP/Down command to receiver. I presume this is same code as transmitter ?
Key UP :
20;1E;DEBUG;Pulses=511;Pulses(uSec)=5010,510,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,90,510,120,510,510,90,120,510,120,510,510,90,90,510,120,510,120,510,510,90,510,90,90,510,510,90,120,510,510,90,510,90,510,90,510,90,510,90,510,90,120,510,510,90,510,90,510,90,510,90,90,510,120,510,120,510,510,90,90,510,510,4920,4920,510,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,120,510,90,510,90,510,90,510,90,510,90,90,510,120,510,510,90,90,510,120,510,510,90,90,510,120,510,90,510,510,90,510,90,90,510,510,90,120,510,510,90,510,90,510,90,510,90,510,90,510,90,90,510,510,90,510,90,510,90,510,90,90,510,90,510,120,510,510,90,90,510,510,4920,4920,510,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,120,510,90,510,510,90,120,510,90,510,510,90,90,510,90,510,120,510,510,90,510,90,90,510,510,90,90,510,510,90,510,90,510,90,510,90,510,90,510,90,90,510,510,90,510,90,510,90,510,90,90,510,90,510,90,510,510,90,90,510,510,4920,4920,510,510,90,510,90,510,90,510,90,510,120,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,120,510,90,510,90,510,90,510,90,510,90,90,510,120,510,510,90,90,510,90,510,510,90,90,510,90,510,90,510,510,90,510,90,90,510,510,90,90,510,510,120,510,120,510,90,510,90,510,90,510,90,90,510,510,90,510,120,510,90,510,120,90,510,90,510,90,510,510,90,120,510,510,4920,4920,510,510,120,510,120,510,90,510,90,510,90,510,90,510,120,510,90,510,90,510,90,510,90,510,90,510,120,510,90,510,90,510,120,510,90,510,90,90,510,120,510,510,90,90,510,120,510,510,90,90,510,90,510,90,510,510,90,510,90,90,510,510,120,90,510,510,90,510,120,510,90,510,120,510,90,510,90,90,510,510,120,510,120,510,90,510,90,90,510,90,510,90,510,510,120,90,510,510,4920,4920,510,510,120,510,90,510,90,510,120,510;
Key StOP :
20;1F;DEBUG;Pulses=511;Pulses(uSec)=5010,510,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,120,510,120,510,510,90,120,510,120,510,510,90,120,510,90,510,120,510,510,90,510,90,120,510,510,90,120,510,510,90,510,90,510,90,510,90,510,90,510,90,120,510,90,510,510,90,510,90,510,90,90,510,120,510,120,510,120,510,510,90,510,4920,4920,510,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,90,510,120,510,510,90,120,510,120,510,510,90,120,510,120,510,120,510,510,90,510,90,120,510,510,90,120,510,510,90,510,90,510,90,510,90,510,90,510,90,120,510,120,510,510,90,510,90,510,90,120,510,120,510,120,510,90,510,510,90,510,4920,4920,510,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,120,510,120,510,510,90,90,510,120,510,510,90,120,510,120,510,90,510,510,90,510,90,120,510,510,90,120,510,510,90,510,90,510,90,510,90,510,90,510,90,120,510,90,510,510,90,510,90,510,90,120,510,90,510,120,510,120,510,510,90,510,4920,4920,510,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,120,510,90,510,510,90,120,510,120,510,510,90,90,510,120,510,120,510,510,90,510,90,120,510,510,90,120,510,510,90,510,90,510,90,510,90,510,90,510,90,120,510,120,510,510,90,510,90,510,90,120,510,120,510,120,510,120,510,510,90,510,4920,4920,510,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,510,90,120,510,120,510,510,90,120,510,90,510,510,90,120,510,120,510,90,510,510,90,510,90,120,510,510,90,90,510,510,90,510,90,510,90,510,90,510,90,510,90,120,510,120,510,510,90,510,90,510,90,120,510,120,510,90,510,120,510,510,90,510,4920,4920,510,510,90,510,90,510,90,510,90,510;
Key Down
20;20;DEBUG;Pulses=511;Pulses(uSec)=570,120,510,90,510,120,510,120,510,120,510,90,510,120,510,120,510,90,510,120,510,90,510,90,510,120,510,120,510,120,510,90,510,120,510,90,90,510,90,510,510,90,90,510,90,510,510,120,90,510,90,510,90,510,510,120,510,90,90,510,510,120,90,510,510,120,510,90,510,120,510,120,510,120,510,120,510,90,90,510,510,120,510,120,510,90,90,510,90,510,90,510,510,120,510,90,510,4920,4920,510,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,90,90,510,90,510,510,120,90,510,90,510,510,120,90,510,90,510,90,510,510,120,510,120,90,510,510,120,90,510,510,120,510,120,510,120,510,120,510,90,510,120,510,120,90,510,510,90,510,90,510,120,90,510,90,510,90,510,510,120,510,120,510,4920,4920,510,510,120,510,90,510,120,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,90,510,120,510,120,90,510,90,510,510,90,90,510,90,510,510,120,90,510,90,510,90,510,510,120,510,120,90,510,510,120,90,510,510,120,510,120,510,90,510,120,510,120,510,120,510,90,90,510,510,120,510,120,510,120,90,510,90,510,90,510,510,120,510,120,510,4920,4920,510,510,120,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,120,90,510,90,510,510,120,90,510,90,510,510,120,90,510,90,510,90,510,510,90,510,120,90,510,510,120,90,510,510,90,510,120,510,120,510,120,510,90,510,120,510,120,90,510,510,120,510,90,510,120,90,510,90,510,90,510,510,120,510,120,510,4920,4920,510,510,120,510,120,510,90,510,120,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,90,510,120,510,120,510,120,510,120,510,90,510,120,90,510,90,510,510,90,90,510,90,510,510,90,90,510,90,510,90,510,510,120,510,120,90,510,510,90,90,510,510,120,510,120,510,90,510,120,510,120,510,120,510,120,90,510,510,120,510,120,510,120,90,510,90,510,90,510,510,120,510,120,510,4920,4920,510,510,90,510,120,510,120,510,90,510,120,510;
Many thanks
Thomas
