hello,
can somebody please explain to me why mosquitto_pub -t wemos/line2 -m "14" update the display on an wemos d1 mini (esp mega) and this one mosquitto_pub -t Wemos_Schlafzimmer/line2 -m "12" doesn't work.
The device ist named "Wemos_Schlafzimmer" and the original path of OpenHAB MQTT ist default.
Greetings
Thomas
[solved] need help by mqtt imports on an oled display
- mqtt_wemos_problem.png (70.37 KiB) Viewed 3148 times
Re: need help by mqtt imports on an oled display
I think you forget the first "/" in your publication. By the way I go with the MQTT standard of not having a leading / in my topics just because of this problem you are facing.
You either add a / in the beginning or change the controller setting by removing the leading / in both publish and subscribe field.
thx grovkillen.
I've found the stupid mistake. Under my MQTT Import device the string contained "wemos". I'll test you informations.
Greetings
Thomas
Greetings
Thomas
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 0 guests
