Rules with combining logic
Elektrofreak
#1 Post by Elektrofreak » 05 Apr 2017, 12:08
Hi all,
I am planning to use a SONOFF with a BH1750 luminosity sensor to control a secondary lamp in a bath room. The ESP will be used without an external controller but with the internal rules.
What I understand is the following example rule:
On brightness#lux do
  if [brighness#lux]>1  // Master light switched on, so turn on relais
    gpio,12,1
    gpio,13,0
  if [brighness#lux]<50  // Master light switched off but light connected to relais still on, so turn off relais
    gpio,12,0
    gpio,13,1
The problem is that the trigger level for turning off is higher than the trigger level for turning on. Thus, I need to take also the current state into consideration. The device monitoring the relais IO is called relais. So I would like to use something like this:
  if [brighness#lux]>1 and [relais#relais] == 0  // Master light switched on, so turn on relais
    gpio,12,1
    gpio,13,0
  if [brighness#lux]<50 and [relais#relais] != 0 // Master light switched off but light connected to relais still on, so turn off relais
    gpio,12,0
    gpio,13,1
But I already crashed the config once and the brightness sensor connected to the SONOFF uses the (disabled) RX and TX lines so I need to re-flach each time I mess up the config :cry: .
Could you tell me if my idea with a combining "and" is possible? Would it be possible to interleave two if loops?
Please help :roll:
paxi
Re: Rules with combining logic
#2 Post by paxi » 06 Apr 2017, 22:41
The rules tutorial states that neither boolean logic nor nesting is supported. :?
You can work around this limitation by creating another rule:
On event1 do
  If condition1 is met
   Event checkAND
On checkAND do
   If condition2 is met
    Desired action
Elektrofreak
#3 Post by Elektrofreak » 18 Apr 2017, 08:26
Thank you for your reply. I will test it and give feedback ;)
toffel969
#4 Post by toffel969 » 18 Apr 2017, 20:24
paxi wrote: 06 Apr 2017, 22:41 The rules tutorial states that neither boolean logic nor nesting is supported. :?
On event1 do
   Event checkAND
On checkAND do
    Desired action
It definitely works. @paxi, I allowed myself to use above to update the rules tutorial in the wiki, trusting it's OK for you
Martinus
#5 Post by Martinus » 18 Apr 2017, 20:32
You should also be able to use a condition directly within the "on xxx" line like this sample that i'm using:
on OutsideLDR#Lux<50 do
  if [Lights#Hal]=0
    SerialSend 10;NewKaku;123454;2;ON;
    SerialSend 10;NewKaku;123455;2;ON;
    TaskValueSet 3,1,1
paxi
#6 Post by paxi » 24 Apr 2017, 09:21
I feel honored toffel969. ;)
Martinus' solution is way more elegant for cases where at least one condition depends on the variable triggering the event. Mine is 'universal'. :D
toffel969
#7 Post by toffel969 » 24 Apr 2017, 09:28
paxi wrote: 24 Apr 2017, 09:21 I feel honored toffel969. ;)
I know :-) I use both of them in combination for MONSTER-rules ;-)
Users browsing this forum: Ahrefs [Bot] and 149 guests
