cannot connect to MQTT broker.
Hello all,
I need some fresh eyes to help troubleshoot my Problem. The ESP indicates that it cannot connect to the broker. I've tested Mosquitto with the following commands as well as a simple andriod app (MyMQTT).
Terminal 1
mosquitto_sub -v -t 'test/topic'
Terminal 2
mosquitto_pub -t 'test/topic' -m 'helloWorld'
This was a successful test. However don't know how to make sure that OpenHAB is receiving or pushing the commands. What topic in the MyMQTT should I put in to the phone to test openHAB?
I'm open to any other suggestions as well.
thank you to the esp8266nu team for a great project.
################################# Generic ESP8266 ######################################
System Info
Uptime: 20 minutes
IP: 192.168.2.189
GW: 192.168.2.1
Build: 20
Unit: 16
STA MAC: 18:fe:34:fe:60:5d
AP MAC: 1a:fe:34:fe:60:5d
ESP Chip ID: 16670813
ESP Flash Size: 524288
Free Mem: 25448
Main Settings
Admin Password: pass
SSID: MYSSID
WPA Key: MYPASSWD
WPA AP Mode Key: configesp
Unit nr: 16
Protocol: OpenHAB MQTT
Controller IP: 192.168.2.125
Controller Port: 1883
Sensor Delay: 60
Message Delay (ms): 1000
Sleep Mode: 0
Optional Settings 0.0.0.0
Fixed IP Octet: 0.0.0.0
ESP IP: 0.0.0.0
ESP GW: 0.0.0.0
ESP Subnet: 0.0.0.0
Syslog IP: 0.0.0.0
Syslog Level: 0
UDP port: 0
Serial log Level: 3
Web log Level: 3
Baud Rate: 115200
################################# OpenHAB MQTT Transport ######################################
# Define your MQTT broker connections here for use in the MQTT Binding or MQTT
# Persistence bundles. Replace <broker> with a id you choose.
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
mqtt:mymosquitto.url=tcp://localhost:1883
# Optional. Client id (max 23 chars) to use when connecting to the broker.
# If not provided a default one is generated.
mqtt:mymosquitto.clientId=openHAB
################################# OpenHAB Items ######################################
Switch MQTTLED (test) {mqtt=">[mymosquitto:/demo/gpio/2:command:ON:1],>[mymosquitto:/demo/gpio/2:command:OFF:0]"}
Terminal 1
Terminal 2
System Info
Uptime: 20 minutes
IP: 192.168.2.189
GW: 192.168.2.1
Build: 20
Unit: 16
Free Mem: 25448
Main Settings
SSID: MYSSID
WPA Key: MYPASSWD
Unit nr: 16
Sensor Delay: 60
Sleep Mode: 0
ESP IP: 0.0.0.0
ESP GW: 0.0.0.0
ESP Subnet: 0.0.0.0
Syslog IP: 0.0.0.0
Syslog Level: 0
UDP port: 0
Serial log Level: 3
Web log Level: 3
Baud Rate: 115200
Re: cannot connect to MQTT broker.
I have confirmed the issue is with ESPEasy after plugging in my old Mosquitto gateway and RFM69HW.
- How can I turn on debug while watching the serial monitor?
- I'll build out my ESP826612 this weekend to see if the problem is limited to the generic ESP.
side note: I've found out that my OpenHab on Raspberry Pi loads and runs better by limiting addons to the one actually used.
Ok. Here's the log. I've attempted this with an ESP826612 as well as a generic.
HTTP : Tools request :
HTTP : Webrequest : reboot
: Rebooting...
ets Jan 8 2013,rst cause:4, boot mode:(3,3)
wdt reset
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
ªU
INIT : Booting Build nr:20
scandone
del if0
usl
sul 0 0
mode : softAP(1a:fe:34:a6:76:90)
add if1
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
bcn 100
bcn 0
del if1
usl
sul 0 0
mode : sta(18:fe:34:a6:76:90)
add if0
WIFI : Connecting...
f 0, .
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 8
pm open phy_2,type:2 0 0
cnt
connected with MYNET, channel 2
dhcp client start...
ip:192.168.2.198,mask:255.255.255.0,gw:192.168.2.1
INIT : I2C
MQTT : Failed to connected to broker
INIT : Boot OK
Boot
0
normal boot
: Rebooting...
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
ªU
scandone
del if0
usl
sul 0 0
add if1
bcn 100
bcn 0
del if1
usl
sul 0 0
add if0
f 0, .
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 8
cnt
INIT : I2C
INIT : Boot OK
Boot
0
normal boot
When the ESP got it's IP, can you ping the device on that IP?
Do you have some generic webserver running so you could try if the ESP connects through HTTP to something?
Use debug level 3 and it should show something like this:
(I have a plain webserver running on 192.168.0.40 and at least it will connect to it even though this is not Domoticz or some other HA solution)
Then we know at least that communication is working and the issue must be something within MQTT connection.
HTTP : connecting to 192.168.0.40
HTTP : closing connection
Thank you for the reply.. I still am having the same problem.
What do you think of the issue being a clentname problem?
My broker is configured to all the defaults which allow anonymous and I don't think that I have a client name configured on any of the other clients (Andriod and Arduino).
The ESP has an IP address. Here's the System Info.
I've updated the logging to level 3 and this is all I get.
I can ping the ESP from the MQTT serverSystem Info
Uptime: 0 minutes
IP: 192.168.2.198
GW: 192.168.2.1
Build: 18
Unit: 16
STA MAC: 18:fe:34:a6:76:90
AP MAC: 1a:fe:34:a6:76:90
ESP Chip ID: 10909328
ESP Flash Size: 4194304
Free Mem: 26232
I still have a problem connecting to the broker. Even though other devices can including my phone and an Arduino Gateway.PING 192.168.2.198 (192.168.2.198) 56(84) bytes of data.
64 bytes from 192.168.2.198: icmp_req=1 ttl=255 time=26.2 ms
64 bytes from 192.168.2.198: icmp_req=2 ttl=255 time=49.2 ms
64 bytes from 192.168.2.198: icmp_req=3 ttl=255 time=2.01 ms
INIT : Booting Build nr:18
INIT : I2C
INIT : Boot OK
Boot
WD : Uptime 0 ConnectFailures 0 FreeMem 26232
Solved BABY!
The issue is with the default Mosquitto repository incompatible with ESP. Credit goes to this post
http://mosquitto.org/2013/01/mosquitto- ... epository/
I uninstalled the existing broker.
To use the new repository you should first import the repository package signing key:
Then make the repository available to apt:
Then one of the following, depending on which version of debian you are using: (I used wheezy)
Then update apt information:
And discover what mosquitto packages are available:
Or just install:
And the sweet result:
sudo /etc/init.d/mosquitto stop
sudo apt-get --purge remove mosquitto mosquitto-clients python-mosquitto
wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
sudo apt-key add mosquitto-repo.gpg.key
cd /etc/apt/sources.list.d/
sudo wget http://repo.mosquitto.org/debian/mosquitto-wheezy.list
sudo wget http://repo.mosquitto.org/debian/mosquitto-jessie.list
apt-get update
apt-cache search mosquitto
apt-get install mosquitto
INIT : I2C
MQTT : Connected to broker
INIT : Boot OK
Boot
gpio,2,0
gpio,2,1
gpio,2,0
Thanks for posting this! Now if I can just figure it out for Windows 7!
That's a bit weird for me. I've reinstalled mosquitto following the sample (I've picked Jessie), and after listed the packages available I chose just install.
After it's been done checked its status:
It says 1.4.8 v3.1
Should I give a try to Wheezy version?
pi@arcpi:~ $ sudo /etc/init.d/mosquitto status
● mosquitto.service - LSB: mosquitto MQTT v3.1 message broker
Loaded: loaded (/etc/init.d/mosquitto)
Active: active (running) since Wed 2016-03-09 16:10:45 CET; 2min 59s ago
Process: 392 ExecStart=/etc/init.d/mosquitto start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/mosquitto.service
└─402 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
Mar 09 16:10:45 arcpi mosquitto[392]: Starting network daemon:: mosquitto.
Mar 09 16:10:45 arcpi systemd[1]: Started LSB: mosquitto MQTT v3.1 message broker.
Tried, but I see no difference. ESP is still unable to connect broker.
I find this interesting:
Still 3.1 and that error message in the last line where this should be: "Opening ipv6 listen socket on port 1883."
Possibly that is wrong here but got no idea how to figure it out.
Any help appreciated.
Active: active (running) since Wed 2016-03-09 16:40:37 CET; 1min 57s ago
Process: 395 ExecStart=/etc/init.d/mosquitto start (code=exited, status=0/SUCCESS)
└─413 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
Mar 09 16:40:37 arcpi mosquitto[395]: Starting network daemon:: mosquitto.
Mar 09 16:40:37 arcpi systemd[1]: Started LSB: mosquitto MQTT v3.1 message broker.
pi@arcpi:~ $ mosquitto
1457538339: mosquitto version 1.4.8 (build date Sun, 14 Feb 2016 15:06:55 +0000) starting
1457538339: Using default config.
1457538339: Opening ipv4 listen socket on port 1883.
1457538339: Error: Address already in use
Looks like your other mosquitto broker may be running.
As far as I know there is no other broker.
OK, after Mosquitto already running typing "mosquitto" to the terminal window tries to start it again, maybe that's the reason.
But still unable to connect to broker.
I read somewhere that there is a syntax issue with "/%sysname%..." -that maybe the "/" is not needed at the beginning... I just can't find it anymore.
check running tasks with "ps" or "ps -xa" to see how many mosquittos are running...
than check connection with mosquitto_sub client...
show what the findings are..
Thank you.
Erased then reinstalled EspEasy, after reboot I get this on serial:
Actually I can't define the lines like "WD : Uptime 0 ConnectFailures 0 FreeMem 26176".
Pi through terminal:INIT : Booting Build nr:78
WIFI : Connecting... 1
WIFI : Connected!
INIT : I2C
Subscribed to: unit1/#
INIT : Boot OK
INIT : Cold Boot
WD : Uptime 1 ConnectFailures 0 FreeMem 26144
WD : Uptime 1 ConnectFailures 0 FreeMem 25952
WD : Uptime 2 ConnectFailures 0 FreeMem 25824
WD : Uptime 2 ConnectFailures 0 FreeMem 25240
WD : Uptime 3 ConnectFailures 0 FreeMem 25760
WD : Uptime 4 ConnectFailures 0 FreeMem 25712
WD : Uptime 5 ConnectFailures 0 FreeMem 25648
WD : Uptime 5 ConnectFailures 0 FreeMem 25632
WD : Uptime 6 ConnectFailures 0 FreeMem 25632
pi@arcpi:~ $ ps -xa
PID TTY STAT TIME COMMAND
1 ? Ss 0:08 /sbin/init
2 ? S 0:00 [kthreadd]
3 ? S 0:04 [ksoftirqd/0]
5 ? S< 0:00 [kworker/0:0H]
7 ? S 0:20 [rcu_sched]
8 ? S 0:00 [rcu_bh]
9 ? S 0:00 [migration/0]
10 ? S 0:00 [migration/1]
11 ? S 0:00 [ksoftirqd/1]
13 ? S< 0:00 [kworker/1:0H]
14 ? S 0:00 [migration/2]
15 ? S 0:00 [ksoftirqd/2]
17 ? S< 0:00 [kworker/2:0H]
18 ? S 0:00 [migration/3]
19 ? S 0:00 [ksoftirqd/3]
21 ? S< 0:00 [kworker/3:0H]
22 ? S< 0:00 [khelper]
23 ? S 0:00 [kdevtmpfs]
24 ? S< 0:00 [netns]
25 ? S< 0:00 [perf]
26 ? S 0:00 [khungtaskd]
27 ? S< 0:00 [writeback]
28 ? S< 0:00 [crypto]
29 ? S< 0:00 [bioset]
30 ? S< 0:00 [kblockd]
32 ? S< 0:00 [rpciod]
34 ? S 0:00 [kswapd0]
35 ? S 0:00 [fsnotify_mark]
36 ? S< 0:00 [nfsiod]
42 ? S< 0:00 [kthrotld]
44 ? S< 0:00 [VCHIQ-0]
45 ? S< 0:00 [VCHIQr-0]
46 ? S< 0:00 [VCHIQs-0]
47 ? S< 0:00 [iscsi_eh]
48 ? S< 0:00 [dwc_otg]
49 ? S< 0:00 [DWC Notificatio]
51 ? S 0:28 [mmcqd/0]
52 ? S 0:00 [VCHIQka-0]
53 ? S< 0:00 [SMIO]
54 ? S< 0:00 [deferwq]
55 ? S 0:10 [jbd2/mmcblk0p2-]
56 ? S< 0:00 [ext4-rsv-conver]
59 ? S< 0:00 [ipv6_addrconf]
107 ? Ss 0:02 /lib/systemd/systemd-journald
108 ? Ss 0:00 /lib/systemd/systemd-udevd
187 ? S 0:00 [spi0]
366 ? S 0:52 [RTW_CMD_THREAD]
381 ? Ss 0:00 /usr/sbin/cron -f
384 ? Ss 0:00 /lib/systemd/systemd-logind
395 ? Ss 0:00 avahi-daemon: running [arcpi.local]
397 ? Ss 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile
413 ? S 0:42 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
418 ? Ss 0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --soc
422 ? S< 0:00 [cfg80211]
426 ? Ss 0:00 /sbin/dhcpcd -q -b
433 ? S 0:00 avahi-daemon: chroot helper
437 ? Ss 0:05 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0
477 ? Ssl 0:00 /usr/sbin/rsyslogd -n
483 ? S< 0:00 [kworker/3:1H]
509 ? Sl 20:58 /usr/bin/java -Djna.boot.library.path=/usr/lib/jni -Dgnu.io.rxtx.Seri
514 ? Ss 0:00 /usr/sbin/sshd -D
527 ? Ssl 0:00 /usr/sbin/lightdm
566 ? Ss 0:10 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:111
614 tty1 Ss 0:00 /bin/login -f
615 ? Ss+ 0:00 /sbin/agetty --keep-baud 115200 38400 9600 ttyAMA0 vt102
635 tty7 Ssl+ 0:34 /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tc
689 ? Sl 0:00 lightdm --session-child 13 16
700 ? Ss 0:00 /lib/systemd/systemd --user
705 ? S 0:00 (sd-pam)
709 ? Ssl 0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
727 ? S< 0:00 [kworker/1:1H]
728 ? Ss 0:15 /usr/sbin/nmbd -D
746 ? Ss 0:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session x-session
749 ? S 0:00 /usr/bin/dbus-launch --exit-with-session x-session-manager
750 ? Ss 0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
760 ? Sl 0:00 /usr/lib/gvfs/gvfsd
766 ? S< 0:00 [kworker/2:1H]
767 ? S< 0:00 [kworker/0:1H]
775 tty1 S+ 0:00 -bash
777 ? Sl 0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
787 ? Ss 0:05 /usr/sbin/smbd -D
832 ? S 0:00 /usr/sbin/smbd -D
843 ? S 0:01 openbox --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
846 ? Sl 0:00 lxpolkit
848 ? Sl 2:44 lxpanel --profile LXDE-pi
849 ? Sl 0:00 pcmanfm --desktop --profile LXDE-pi
858 ? Ss 0:00 /usr/bin/ssh-agent -s
860 ? Ssl 0:00 /usr/lib/policykit-1/polkitd --no-debug
869 ? Sl 0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
871 ? Ssl 0:00 /usr/lib/udisks2/udisksd --no-debug
883 ? Sl 0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
887 ? Sl 0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
892 ? Sl 0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
896 ? Sl 0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
911 ? Sl 0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.1 /org/gtk/gvfs/exec_spaw/0
912 ? Ssl 0:00 /usr/lib/menu-cache/menu-cached /tmp/.menu-cached-:0-pi
10798 ? S 0:00 [kworker/u8:1]
16470 ? S 0:01 [kworker/u8:0]
17887 ? S 0:01 [kworker/1:2]
18225 ? S 0:00 [kworker/2:0]
18882 ? S 0:00 [kworker/3:2]
18908 ? S 0:00 [kworker/2:1]
18926 ? S 0:00 [kworker/1:1]
18938 ? S 0:00 [kworker/0:2]
18967 ? S 0:00 [kworker/3:1]
19014 ? S 0:00 [kworker/0:1]
19078 ? S 0:00 [kworker/2:2]
19094 ? Ss 0:00 sshd: pi [priv]
19096 ? S 0:00 [kworker/0:0]
19103 ? Ss 0:00 sshd: pi [priv]
19106 ? S 0:00 sshd: pi@pts/0
19118 ? S 0:00 sshd: pi@notty
19121 ? Ss 0:00 /usr/lib/openssh/sftp-server
19122 pts/0 Ss 0:00 -bash
19162 pts/0 R+ 0:00 ps -xa
It seems almost OK now, isn't it?pi@arcpi:~ $ mosquitto_sub -d -t unit1/#
Client mosqsub/19358-arcpi sending CONNECT
Client mosqsub/19358-arcpi received CONNACK
Client mosqsub/19358-arcpi sending SUBSCRIBE (Mid: 1, Topic: unit1/#, QoS: 0)
Client mosqsub/19358-arcpi received SUBACK
Subscribed (mid: 1): 0
Client mosqsub/19358-arcpi sending PINGREQ
Client mosqsub/19358-arcpi received PINGRESP
Perfect.
Now I can turn GPIOs on and off through the broker.
How should the responses (state change confirmation) appear from the ESP on the broker? Later I want to drive my nodes via OpenHab, so I'll need to have status reports to keep it sane...
Subscribed to the topic unit1/# -and when I manually publish on it I see this:
but nothing from the ESP.
Client mosqsub/19358-arcpi received PUBLISH (d0, q0, r0, m0, 'unit1/gpio/2', ... (1 bytes))
0
0
1
do you enabled sending for the GPIO?
may check here some more hints for this:
http://www.esp8266.nu/forum/viewtopic.p ... e%25#p4886
Thank you, already read that.
SUB template:%sysname%/#
PUB template: %sysname%/%tskname%/%valname%
Removed the first "/"
My question is to be exact: I should see the ESP's response on the mosquitto_sub terminal under "unit1/#" topic, right?
Thank you for your time and effort.
http://www.hivemq.com/blog/mqtt-essenti ... -practicesDon’t use a leading forward slash
It is allowed to use a leading forward slash in MQTT, for example /myhome/groundfloor/livingroom. But that introduces a unnecessary topic level with a zero character at the front. That should be avoided, because it doesn’t provide any benefit and often leads to confusion.
Hi all,
I am new here and needs all the help.
I am using Ubuntu 16.10 default mosquitto installation on a local host, the MQTT clients can log on to it without any problem.
Flashed sonoff device with R147 ESPeasy
This thread is of great help, so I set in the "advanced" tool section of the ESP easy (removed the first / in each)
subscribe template: %sysname%/
publish template: %sysname%/%tskname%/%valname%
and the subscription topic of : sonoff1/# is working, I am getting system info from subscription.
However the publish part become a problem
I have tried : sonoff1/gpio/12 or sonoff1/gpio/0 or sonoff1/lightswitch/Switch with no success the lightswitch and Switch are the task name and value in the Device configuration.
Before the above, I have the "/" in front of the template and "/" in front of subscribe or publish that does not work either.
Ok Ok its all good
it turned out that while subscribe you cannot have a / , publish you need a /
it is weird
So the templates
subscribe : %sysname%/
publish : %sysname%/%tskname%/%valname%
But the clients need
subscribe: sonoff1/#
publish: /sonoff1/gpio/0 or 12
minor difference, but major headache.
In the commercial broker such as cloudmqtt and mqtt-dashboard
the subscribe template must be /%sysname%/
the publish template must be /%sysname%/%tskname%/%valname%
and the clients call must have / in front
it is weird
So the templates
Ok, now after reboot the conventions seem corrected themselves
So the templates
Then the clients need
publish: sonoff1/gpio/0 or 12
no more / in the publish phase
So the templates
I think many cloud based brokers use a unique identifier for the clients, thus the need to have a leading slash (which isn't leading really). I.e.
123e4567-e89b-12d3-a456-42665544000/sonoff1/gpio/0
Users browsing this forum: No registered users and 38 guests
