ESP8266 relay for domoticz
I check but without results. This is possible with R120 or R147 ? I want only connect relay on and off. Time for switch on i want to set in Domoticz.
Some Raspeberry Pi's, Arduinos, Esp8266, solar panels 1500w, 2 lakes,6 ha fields, German shepherd and more
Re: ESP8266 relay for domoticz
https://www.letscontrolit.com/wiki/index.php/GPIOBasic on/off
We can control a pin with simple http url commands. To change the pin to high or low steady output:
http://<ESP IP address>/control?cmd=GPIO,<pin>,0
http://<ESP IP address>/control?cmd=GPIO,<pin>,1
- relay.jpg (160.95 KiB) Viewed 5388 times
This is easy. Thank you. What pins connect relays to esp-07 ?
Thank you. I try.
