Daily Flash rate exceeded ...
JR01
#1 Post by JR01 » 17 Apr 2017, 18:38
Hi, just loaded v2.0.0-dev7, from v147, an ESP with 5 relays, temp, etc. Thus, had to reload all the Devices, and got same as others on this forum:
viewtopic.php?f=18&t=2257&hilit=FS+%3A+ ... =20#p12414
Now I am unable to complete a critical setup for a garden watering system, as I cannot write any further, and I do not have the time to change code and compile myself.
Should the limit not be moved up from 100 for the normal binaries loaded on the download site?
JR01
Re: Daily Flash rate exceeded ...
#2 Post by JR01 » 18 Apr 2017, 07:27
Hi Edwin, may I please ask for an urgent solution here, my sprinkling system is now broken, I waited a day, thinking that the 'daily flash rate' means daily', but this still does not work the next day to add the last Device?
JR01
#3 Post by JR01 » 18 Apr 2017, 07:47
Found a work around, a power off/on cycle sorts it out.
Martinus
#4 Post by Martinus » 18 Apr 2017, 20:25
There's also an undocumented command to reset the daily counter:
resetFlashWriteCounter
JR01
#5 Post by JR01 » 18 Apr 2017, 23:18
Fantastic, thank you !
