MiLight gives me 20;16;CMD UNKNOWN;
olskar
#1 Post by olskar » 15 May 2017, 17:17
I get this error when trying to pair my RGBW MiLIght?
2017-05-15 17:16:36.119 User: initiated a RFLink Device Create command: 10;MiLightv1;F746;01;34BC;PAIR;
2017-05-15 17:16:36.194 RFLink: 20;16;CMD UNKNOWN;
2017-05-15 17:16:36.194 Error: RFLink: Error/Unknown command received!...
darkside0506
Re: MiLight gives me 20;16;CMD UNKNOWN;
#2 Post by darkside0506 » 15 May 2017, 20:17
Have you turned on MiLight in the loader program?
olskar
#3 Post by olskar » 15 May 2017, 20:29
Don't have the loader program, but gave the command 20;01;MiLigt=ON;
That should do the same thing as I understand it
darkside0506
#4 Post by darkside0506 » 15 May 2017, 21:22
I don't know if it does, someone more knowledgable than me might be able to confirm either way.
You could download the loader program from the website (it comes with the firmware download iirc). Connect mega to usb and turn on serial port logging then press the "milight on" button. When you run the serial logging it will tell you if milight is on and also if your nrf24xxx module is detected properly.
Stuntteam
Site Beheer
#5 Post by Stuntteam » 15 May 2017, 23:59
The command is not correct.. make sure you spelled it right.
olskar
#6 Post by olskar » 17 May 2017, 12:45
Stuntteam wrote: 15 May 2017, 23:59 The command is not correct.. make sure you spelled it right.
I copied the command from your faq, is that not correct?
http://www.nemcon.nl/blog2/faq#Freq3
olskar
#7 Post by olskar » 17 May 2017, 12:46
darkside0506 wrote: 15 May 2017, 21:22 I don't know if it does, someone more knowledgable than me might be able to confirm either way.
The loader is windows only and dont have windows :(
Stuntteam
Site Beheer
#8 Post by Stuntteam » 17 May 2017, 17:03
Commands starting with 20; are responses from RFLink.
Also "20;01;MiLigt=ON;" the spellign of milight is wrong.
The right command is:
10;setMilight=ON;
