Wat doe ik fout? de SendToHTTP werkt wel, maar de SendTO met unit nummer werkt niet. Unit 4 is absoluut het goede nummer en er is geen ander met dit nummer.
on Deurbel#Deurbel do
// sendTo 4,event,deurbel //(to use the previous example.)
SendToHTTP 192.168.0.31,80,/control?cmd=event,deurbel
sendTo werkt niet, sendToHTTP wel
Re: sendTo werkt niet, sendToHTTP wel
Did you set the UDP Port I advanced tab to the value on all units? Does the node list on the start page work? Anyhow http is the more reliable protocol (acknowledgment that packet wa received, resend on error)
1) Wrong language...ensingg wrote: ↑19 Jul 2017, 13:34 Wat doe ik fout? de SendToHTTP werkt wel, maar de SendTO met unit nummer werkt niet. Unit 4 is absoluut het goede nummer en er is geen ander met dit nummer.
2) No config data
Conclusion: insufficient data leading to no help...
Now that's a bit rude
, I tried despite 1+2 ![Erg Blij :D](./images/smilies/icon_e_biggrin.gif)
![Knipoog ;)](./images/smilies/icon_e_wink.gif)
Thanks for the reactions (and the correction ![Knipoog ;-)](./images/smilies/icon_e_wink.gif)
I didnt know of the UDP setting in advanced. But don't like UDP so I will use the sendToHTTP instead of the sendTO.
This topic can be closed.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
