Turn off i2c sensor when esp is in deep sleep
Hi all,
Has anyone developed a solution to run a esp8266 with espeasy and an i2c sensor, where the sensor is switched of, when esp is in deep sleep. When sensor is not turned off, it will empty the battery.
Any ideas or plans ho to realize that.
Best regards
Karl
Best regards
Karl
Re: Turn off i2c sensor when esp is in deep sleep
You can always use a relay that cut the incoming current to the sensor(s).
A Relay??? Doesn't that eat a LOT of precious power?grovkillen wrote: ↑23 Aug 2017, 18:32 You can always use a relay that cut the incoming current to the sensor(s).
Google is your friend:
Yes you are right but that depends on the battery. Here's a low power consumption relay: http://www.azettler.com/ultra-low-power ... lications/
Of course i can switch it off via relay. Thanks for the transistor solution!
How should parameters for espeasy should look like? How can i configure espeasy in order to activate a gpio for lets say 15 sec.or for uptime of esp...
By the way, i am using that kind of battery shield, which works very well https://www.aliexpress.com/item/Wemos-1 ... st=ae803_2
K
K
Thanks for that link! Ordered 2 straight away!karl222 wrote: ↑24 Aug 2017, 10:32 ...
what is the difference between this "shield" (whic is not a shield ) and a normal power bank for 1x18650 that can be found for 1€ or less?
as well I built for testing purpouses a simple "shiled" with a 18650 battery holder and a TP4056 module which gives same functionality of this one and as well GND separation betweek charing circuit and output pins
I agree with papperone: The battery shield doesn't make any sense to me, since you're using an usb cable anyway why not use an usb battery pack? You can buy them anywhere cheap and it will last a lot longer then an AA battery...karl222 wrote: ↑24 Aug 2017, 10:32 Of course i can switch it off via relay. Thanks for the transistor solution!
K
As far as i know the ESP does a reboot when waking from deepsleep.
If I remember this correct then any solution with a relay or transistor to switch an I²C sensor will fail.
On startup the I²C init runs before the rules start. But it needs a rule to switch the relay or transistor
so the I²C init runs before the sensor is powered. So no values will be shown ever.
It might be possible if the driving GPIO is set to high by hardware settings. I don't know how these settings behave in deepsleep.
The best way would be using the built-in sleep functions of the sensor.
Anyways the question is if these efforts pay at all. A view into datasheets helps to decide.
For example the BME-280 driven in "auto-mode", (highest power consumption) metering all vallues once per second
has a power consumption of 3,6µA! From the datasheet:
So a well prepared BME-280 or modified (voltage regulator removed) breakout board with BME-280 should run for long times.
A SI7021 (SHT21 Sensor) needs much more current, around 330µA. If the sensor is heated for reconditioning it may rise to 1,5 mA
so it will pay to put this sensor into sleep mode.
So at the end the way is to first take a look into datasheets and chose the sensor wisely.
This might make all of the changes and circuits obsolete.
3.6 µA @ 1 Hz humidity, pressure and temperature
Just use gpio15, this pin goes to zero at bootup time therefore enabling the sensor by default...Shardan wrote: ↑24 Aug 2017, 15:13 As far as i know the ESP does a reboot when waking from deepsleep.
So a well prepared BME-280 or modified (voltage regulator removed) breakout board with BME-280 should run for long times.Code: Select all
The MH-Z19 uses a LOT more power: upto 18mA average!
many thanks for your input. the smartest way to get a long battery duration is to use a sensor with low current like the BME 280. I am going to use this one.
best regards
karl
best regards
karl
I have an outdoor unit, BME280, ESP8285, single 18650 battery, a small solar cell and charging circuit. I have not had a problem yet, but I am waiting to see if it will last through the winter without going down. There are a lot of cloudy days over the winter.
IF needed you could use soemthing like a MCP-1825 with enable pin as a separate power supply for the sensors and tie to CH_EN on the esp. When the ESP goes to sleep, it should pull the enable pin low and turn off the power supply.
I am also waiting for a new component, 512-KA75330ZTA, to keep the battery from getting drained down too far. When the battery voltage drops below 3.3V it should shut down the MCP1825 and when the power comes back up, it should turn on again. In theory, reality may be different. Should have some in my hands to try this week.
interesting!
please keep me updated
with my solution I am running the sensor 6-8 weeks on one full 18650 cell... this is ok for me now.
regards
karl
regards
karl
KA75330ZTA seems to be working. The 18650 was 3.3V when I replaced it today on a soil moisture sensor I have been testing. This one has a small solar cell in a window so it ocasionally runs out when we have cloudy days.
I need to do some more testing to make sure it will recover.
Users browsing this forum: No registered users and 29 guests
