v2.0.0-dev11: two INA219 Devices get the same address
Hello!
Can someone please confirm that there is a bug in the INA219 Plugin, if you use more than one device?
The last submitted i2c address will be used for both devices:
### Steps to reproduce
How can we trigger this problem?
Create one INA219 Device with address 0x40 and a second one with 0x41. In the log you can see that the last address 0x41 is used for both devices.
ESP Easy Mega: ESP8266-PD1
MainConfigControllersHardwareDevicesRulesNotificationsTools
Log
2527551 : WD : Uptime 42 ConnectFailures 0 FreeMem 21288
2555790 : INA219 0x41: Voltage: 23.93 Current: 0.03 Power: 0.62
2555790 : EVENT: InputA#VoltageA=23.93
2555918 : EVENT: InputA#CurrentA=0.03
2556051 : EVENT: InputA#PowerA=0.62
2556799 : INA219 0x41: Voltage: 23.95 Current: 0.03 Power: 0.64
2556800 : EVENT: InputB#VoltageB=23.95
2556926 : EVENT: InputB#CurrentB=0.03
2557058 : EVENT: InputB#PowerB=0.64
2557552 : WD : Uptime 43 ConnectFailures 0 FreeMem 21040
Powered by www.letscontrolit.com
If you go back to the device with 0x40 and click „Submit“ again then it uses 0x40 for both devices:
Log
2434661 : INA219 0x40: Voltage: 5.02 Current: 0.23 Power: 1.16
2434661 : EVENT: InputA#VoltageA=5.02
2434787 : EVENT: InputA#CurrentA=0.23
2434925 : EVENT: InputA#PowerA=1.16
2435667 : INA219 0x40: Voltage: 5.02 Current: 0.23 Power: 1.17
2435668 : EVENT: InputB#VoltageB=5.02
2435796 : EVENT: InputB#CurrentB=0.23
2435930 : EVENT: InputB#PowerB=1.17
2436638 : WD : Uptime 41 ConnectFailures 0 FreeMem 21288
2443645 : EVENT: Clock#Time=Thu,20:21
Does the problem presist after powering off and on? (just resetting isnt enough sometimes)
Yes, the problem persists after powering off and on.
### Expected behavior
Tell us what should happen?
Every INA219 Device should get the right address:
e.g. the log should look like this:
### Actual behavior
Tell us what happens instead?
see description above (### Steps to reproduce)
### System configuration
Hardware:
D1 mini, two IDA219 Devices and an OLED SSD1306 Framed
Software or git version:
Release v2.0.0-dev11 (I downloaded from github and built the Version yesterday)
Thanks in advance.
Log
Log
### Actual behavior
Hardware:
Thanks in advance.
Re: v2.0.0-dev11: two INA219 Devices get the same address
Have you changed the address by bridging the pads through soldering?
https://www.google.se/search?q=ina219+i ... 07m04Tr3BM:
Yes, I used the adafruit tutorial to change the address on one INA219 like in the photo and how to wire the devices.
One Module has the standard address 0x40 and the other 0x41 like in the photo.
Please file an report on the GitHub for this. I can do it if you don't want to.
Hallo @grovkillen,
I filed a report on GitHub #491.
Kind regards,
Red.
Kind regards,
Red.
Good! I hope it get sorted out.
I'm not a programmer, but I decided to take a look at the code of the INA219 Plugin 027 anyway. My understanding is, that there is only one global variable for the i2c address (ina219_i2caddr) and if you use more than one INA219 device, it gets overwritten by the last device where you have clicked the submit button. How do we fix that?
Well, I can't correct this in an elegant way, but found a solution to work around this problem:
I copied the 027 plugin and renamed the copy to e.g. 200, then I replaced every 027 inside of the new plugin to 200 and one 27 to 200 (PLUGIN_ID_027). Of cause the compiler threw three errors: three variables were already used by the 027 plugin, so we need to change them:
ina219_i2caddr, ina219_calValue and ina219_currentDivider_mA
to e.g.:
ina219_i2caddr2, ina219_calValue2 and ina219_currentDivider_mA2
To better distinguish both plugins in the drop down menu, I decided to use "Voltage & Current (DC) - INA219 0x41" (PLUGIN_NAME_200) for the name of the new plugin.
If you want to use three or four INA219 Modules, you need to create more copies of the plugin. Keep one or two eyes on the memory usage and ditch some plugins which you don't need.
This little hack works great for me, I hope this was interesting for you and maybe it will help you too.
Regards,
Red.
to e.g.:
Regards,
Red.
I just added a pull request for this bug: https://github.com/letscontrolit/ESPEasy/pull/519
Only problem is that I do not have these sensor, so it was just changing for what I thought is needed, no testing.
So please if someone can test it?
Users browsing this forum: No registered users and 44 guests
