More support for i2c modules/sensors [UPDATED 25.09.2016]
beic
#1 Post by beic » 16 Sep 2016, 21:39
Hi there,
Is there any chance to add more i2c modules/sensors like on my list bellow?
I found a few of them on AliExpress and they seems to be wort for adding them as new plugins/devices.
These are just my toughs, but maybe someone will like the idea too, because I'm using the ESP-01 and ESP-01S modules with 1Mb, and you know, there only two data line available!
1. LM75A High-Speed Temperature Sensor
https://www.aliexpress.com/item/LM75A-T ... 27860.html
2. SI1145 UV IR Visible Sensor
https://www.aliexpress.com/item/SI1145- ... 05707.html
3. APDS-9960 RGB and Gesture Sensor Module
https://www.aliexpress.com/item/GY-9960 ... 14031.html
4. RTC DS1307 AT24C32 Real Time Clock Module
https://www.aliexpress.com/item/2016-Ne ... 35694.html
5. MCP4725 I2C DAC Breakout Board 12-Bit DAC w/I2C Interface
https://www.aliexpress.com/item/1pcs-MC ... 78308.html
6. MPR121 Breakout v12 Capacitive Touch Sensor Controller Module
https://www.aliexpress.com/item/New-MPR ... 32709.html
7. TCA9548A 1-to-8 I2C 8-way Multi-Channel Expansion Board
https://www.aliexpress.com/item/CJMCU-9 ... 64206.html
8. ADS1110 16-bit ADC with Onboard Reference
https://www.aliexpress.com/store/produc ... 96465.html
To be continued... ;)
costo
Re: More support for i2c modules/sensors
#2 Post by costo » 16 Sep 2016, 22:24
@ beic
You did not do your homework very well.
ADS1115 is already supported since version R60.
Support for clock boards like DS1307 and DS3231 is pretty useless because over WiFi you can connect to a NTP timeserver, much more accurate than a DS1307.
beic
#3 Post by beic » 16 Sep 2016, 22:35
costo wrote: You did not do your homework very well. ADS1115 is already supported since version R60.
Sorry, I didn't see it! I will remove it! :oops:
costo wrote: Support for clock boards like DS1307 and DS3231 is pretty useless because over WiFi you can connect to a NTP timeserver, much more accurate than a DS1307.
I just tough, for that to be able to display the current time and date on OLED 128x64 Display with ESP Easy.
Thank you!
EDIT: Ahh, I found it under menu TOOLS > ADVANCED ... Use NTP and NTP Hostname (optional: Timezone Offset), but there is only TIME shown on MAIN menu, I tough that the DATE will appear too! :?
vibrog
Re: More support for i2c modules/sensors [UPDATED 25.09.2016]
#4 Post by vibrog » 24 Aug 2017, 12:14
The APDS-9960 would be really interesting:
https://youtu.be/A3QRyixnEl8
LisaM
#5 Post by LisaM » 24 Aug 2017, 14:02
beic wrote:
16 Sep 2016, 21:39
The REAL question here is, what's keeping you from:
- Buying the sensor from Ali
- Build a plugin for it
- Test the plugin
- Publish the plugin
It's always easy to ask others to do your work...
beic
#6 Post by beic » 24 Aug 2017, 19:21
LisaM wrote:
24 Aug 2017, 14:02
Yeah, like you, using the whole project what others built...
Kind regards
LisaM
#7 Post by LisaM » 24 Aug 2017, 19:34
beic wrote:
24 Aug 2017, 19:21
Actually i've rebuild P013 to include new sonic sensors, helped test HLW8012, ArduinoEasy.
Pick a sensor and start building... ;)
papperone
#8 Post by papperone » 24 Aug 2017, 19:46
vibrog wrote:
24 Aug 2017, 12:14
it was enough to look at GitHub to see there's already a plugin unde development in the dev11 release --> _P064_APDS9960.ino
LisaM
#9 Post by LisaM » 24 Aug 2017, 20:08
papperone wrote:
24 Aug 2017, 19:46
vibrog wrote:
24 Aug 2017, 12:14
If we all build just ONE plugin, we'll have a plugin library spanning all sensors... 8-)
beic
#10 Post by beic » 24 Aug 2017, 22:29
LisaM wrote:
24 Aug 2017, 19:34
Really?!? I built a few to, like SHT30 and LM75A.
toffel969
#11 Post by toffel969 » 25 Aug 2017, 07:28
Chill people 8-) I am sure you both contribute to best you can. It's not a competition... not everyone has same abilities/time to spare/energy, everyone to their abilities.
beic
#12 Post by beic » 25 Aug 2017, 08:28
toffel969 wrote:
25 Aug 2017, 07:28
Yes, but, unfortunately Lisa can't understand that! ;)
LisaM
#13 Post by LisaM » 25 Aug 2017, 13:18
beic wrote:
25 Aug 2017, 08:28
toffel969 wrote:
25 Aug 2017, 07:28
:mrgreen:
beic
#14 Post by beic » 25 Aug 2017, 19:03
LisaM wrote:
25 Aug 2017, 13:18
beic wrote:
25 Aug 2017, 08:28
toffel969 wrote:
25 Aug 2017, 07:28
:mrgreen:
Kappa :D
Hairyloon
#15 Post by Hairyloon » 14 Jun 2019, 16:16
LisaM wrote:
24 Aug 2017, 14:02
Hey, some of us just aren't that clever. :(
Users browsing this forum: No registered users and 6 guests
