Fine Offset WH1080, WH1081 868MHz is not recognized?
WeatherOffset
#1 Post by WeatherOffset » 05 Jul 2017, 09:26
I have a Fine Offset WH1080,WH1081(Proove WP1400) weatherstation with 868MHz sensor and that is not recognized by the RFlink gateway with a 868MHz transciever mounted. Other sensors are received.
Is this a known issue?
Stuntteam
Site Beheer
Re: Fine Offset WH1080, WH1081 868MHz is not recognized?
#2 Post by Stuntteam » 05 Jul 2017, 13:58
It should work.. make a debug log and mail that to me.. frankzirrone@gmail.com
WeatherOffset
#3 Post by WeatherOffset » 06 Jul 2017, 11:41
Ok, thanks!
I have sent you an email now!
WeatherOffset
#4 Post by WeatherOffset » 29 Aug 2017, 14:22
Hi again!
I found some information about Fine Offset WH1080, WH1081. It seems like the have changed the protocol in 2012 from OOK modulation to FSK modulation in the protocol for the new units.
My unit is from 2007. Is OOK protocol supported by the RFLink 868MHz version?
chrille
#5 Post by chrille » 30 Aug 2017, 13:21
WeatherOffset wrote: 05 Jul 2017, 09:26 I have a Fine Offset WH1080,WH1081(Proove WP1400) weatherstation with 868MHz sensor and that is not recognized by the RFlink gateway with a 868MHz transciever mounted. Other sensors are received.
What module are you using for receiving 868 MHz? CC1101? I have a WH 1090 which I think is very similar on the radio interface and would like to test that
- Jan
Jan Chrillesen, Denmark
Stuntteam
Site Beheer
#6 Post by Stuntteam » 30 Aug 2017, 13:59
RFlink supports the OOK version using an Aurel 868mhz transceiver
Grant Hall
#7 Post by Grant Hall » 08 Sep 2017, 09:24
Ok, I'll give it a try.
I know a secret. Yeah, I'm not a professional gambler, but luck has nothing to do with me anymore. I think I should continue reading this in order to show up there next year.
Users browsing this forum: No registered users and 4 guests
