I am trying to use a Sonoff Pow, and a have found out that ESPEasyPluginPlayground has the _P170_HLW8012.ino file.
When I try to export to a binary file, it says I need a HLW8012.h file.
how do I get this file.
missing .h file Arduino IDE
Re: missing .h file Arduino IDE
please serch first as there's a thread about this device where I'm collecting feedback and input if any bugs
your question has been already answered --> http://www.letscontrolit.com/forum/view ... =50#p17163
thanks
now I get some new errors, could you me help again?
Arduino: 1.8.3 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
WARNING: Category 'LED' in library CHT16K33 LED Matrix Library is not valid. Setting to 'Uncategorized'
WARNING: Category 'Input' in library MechInputs is not valid. Setting to 'Uncategorized'
C:\Program Files (x86)\Arduino\libraries\_P170_HLW8012\_P170_HLW8012.ino: In function 'boolean Plugin_170(byte, EventStruct*, String&)':
_P170_HLW8012:49: error: 'PLUGIN_DEVICE_ADD' was not declared in this scope
case PLUGIN_DEVICE_ADD:
_P170_HLW8012:51: error: 'Device' was not declared in this scope
Device[++deviceCount].Number = PLUGIN_ID_170;
_P170_HLW8012:51: error: 'deviceCount' was not declared in this scope
_P170_HLW8012:52: error: 'DEVICE_TYPE_TRIPLE' was not declared in this scope
Device[deviceCount].Type = DEVICE_TYPE_TRIPLE;
_P170_HLW8012:53: error: 'SENSOR_TYPE_QUAD' was not declared in this scope
Device[deviceCount].VType = SENSOR_TYPE_QUAD;
_P170_HLW8012:65: error: 'PLUGIN_GET_DEVICENAME' was not declared in this scope
case PLUGIN_GET_DEVICENAME:
_P170_HLW8012:71: error: 'PLUGIN_GET_DEVICEVALUENAMES' was not declared in this scope
In file included from C:\Users\Mads\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Arduino.h:240:0,
from sketch\_P170_HLW8012.ino.cpp:1:
_P170_HLW8012:73: error: 'ExtraTaskSettings' was not declared in this scope
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_170));
C:\Users\Mads\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/pgmspace.h:61:49: note: in definition of macro 'strcpy_P'
#define strcpy_P(dest, src) strncpy_P((dest), (src), SIZE_IRRELEVANT)
_P170_HLW8012:80: error: 'PLUGIN_WEBFORM_LOAD' was not declared in this scope
case PLUGIN_WEBFORM_LOAD:
_P170_HLW8012:82: error: 'addFormNote' was not declared in this scope
addFormNote(string, F("Sonoff POW: 1st(SEL)=GPIO-5, 2nd(CF1)=GPIO-13, 3rd(CF)=GPIO-14"));
_P170_HLW8012:83: error: 'addFormSubHeader' was not declared in this scope
addFormSubHeader(string, F("Calibration Values"));
_P170_HLW8012:85: error: invalid use of incomplete type 'struct EventStruct'
LoadCustomTaskSettings(event->TaskIndex, (byte*)&hlwMultipliers, sizeof(hlwMultipliers));
_P170_HLW8012:43: error: forward declaration of 'struct EventStruct'
boolean Plugin_170(byte function, struct EventStruct *event, String& string)
_P170_HLW8012:85: error: 'LoadCustomTaskSettings' was not declared in this scope
_P170_HLW8012:86: error: 'addFormTextBox' was not declared in this scope
addFormTextBox(string, F("Current Multiplier"), F("plugin_170_currmult"), String(hlwMultipliers[0], 2), 25);
_P170_HLW8012:93: error: 'PLUGIN_WEBFORM_SAVE' was not declared in this scope
case PLUGIN_WEBFORM_SAVE:
_P170_HLW8012:97: error: 'WebServer' was not declared in this scope
arg1 = F("plugin_170_currmult"); tmpString = WebServer.arg(arg1);
_P170_HLW8012:103: error: invalid use of incomplete type 'struct EventStruct'
SaveCustomTaskSettings(event->TaskIndex, (byte*)&hlwMultipliers, sizeof(hlwMultipliers));
_P170_HLW8012:103: error: 'SaveCustomTaskSettings' was not declared in this scope
_P170_HLW8012:106: error: 'LOG_LEVEL_INFO' was not declared in this scope
addLog(LOG_LEVEL_INFO, log);
_P170_HLW8012:106: error: 'addLog' was not declared in this scope
_P170_HLW8012:115: error: 'LOG_LEVEL_INFO' was not declared in this scope
_P170_HLW8012:115: error: 'addLog' was not declared in this scope
_P170_HLW8012:122: error: 'PLUGIN_READ' was not declared in this scope
case PLUGIN_READ:
_P170_HLW8012:135: error: 'LOG_LEVEL_INFO' was not declared in this scope
_P170_HLW8012:135: error: 'addLog' was not declared in this scope
_P170_HLW8012:137: error: 'UserVar' was not declared in this scope
UserVar[event->BaseVarIndex] = hvoltage;
_P170_HLW8012:137: error: invalid use of incomplete type 'struct EventStruct'
_P170_HLW8012:138: error: invalid use of incomplete type 'struct EventStruct'
UserVar[event->BaseVarIndex + 1] = hcurrent;
_P170_HLW8012:139: error: invalid use of incomplete type 'struct EventStruct'
UserVar[event->BaseVarIndex + 2] = hpower;
_P170_HLW8012:140: error: invalid use of incomplete type 'struct EventStruct'
UserVar[event->BaseVarIndex + 3] = hpowfact;
_P170_HLW8012:146: error: 'PLUGIN_INIT' was not declared in this scope
case PLUGIN_INIT:
_P170_HLW8012:152: error: 'Settings' was not declared in this scope
Plugin_170_hlw->begin(Settings.TaskDevicePin3[event->TaskIndex], Settings.TaskDevicePin2[event->TaskIndex], Settings.TaskDevicePin1[event->TaskIndex], HLW_CURRENT_MODE, false, 1000000);
_P170_HLW8012:152: error: invalid use of incomplete type 'struct EventStruct'
_P170_HLW8012:153: error: 'LOG_LEVEL_INFO' was not declared in this scope
if (PLUGIN_170_DEBUG) addLog(LOG_LEVEL_INFO, F("HLW8012: Init object done"));
_P170_HLW8012:153: error: 'addLog' was not declared in this scope
_P170_HLW8012:155: error: 'LOG_LEVEL_INFO' was not declared in this scope
if (PLUGIN_170_DEBUG) addLog(LOG_LEVEL_INFO, F("HLW8012: Init Basic Resistor Values done"));
_P170_HLW8012:155: error: 'addLog' was not declared in this scope
_P170_HLW8012:158: error: invalid use of incomplete type 'struct EventStruct'
_P170_HLW8012:158: error: 'LoadCustomTaskSettings' was not declared in this scope
_P170_HLW8012:162: error: invalid use of incomplete type 'struct EventStruct'
_P170_HLW8012:162: error: 'SaveCustomTaskSettings' was not declared in this scope
_P170_HLW8012:163: error: 'LOG_LEVEL_INFO' was not declared in this scope
if (PLUGIN_170_DEBUG) addLog(LOG_LEVEL_INFO, F("HLW8012: Saved Calibration after INIT"));
_P170_HLW8012:163: error: 'addLog' was not declared in this scope
_P170_HLW8012:164: error: invalid use of incomplete type 'struct EventStruct'
StoredTaskIndex = event->TaskIndex; // store task index value in order to use it in the PLUGIN_WRITE routine
_P170_HLW8012:170: error: 'PLUGIN_WRITE' was not declared in this scope
case PLUGIN_WRITE:
_P170_HLW8012:183: error: 'LOG_LEVEL_INFO' was not declared in this scope
if (PLUGIN_170_DEBUG) addLog(LOG_LEVEL_INFO, F("HLW8012: Reset Multipliers to DEFAULT"));
_P170_HLW8012:183: error: 'addLog' was not declared in this scope
_P170_HLW8012:213: error: 'LOG_LEVEL_INFO' was not declared in this scope
_P170_HLW8012:213: error: 'addLog' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\_P170_HLW8012\_P170_HLW8012.ino: In function 'void Plugin170_SaveMultipliers()':
_P170_HLW8012:235: error: 'SaveCustomTaskSettings' was not declared in this scope
SaveCustomTaskSettings(StoredTaskIndex, (byte*)&hlwMultipliers, sizeof(hlwMultipliers));
Multiple libraries were found for "HLW8012.h"
Used: C:\Users\Mads\Documents\Arduino\libraries\_P170_HLW8012
Not used: C:\Users\Mads\Documents\Arduino\libraries\_P170_HLW8012_2
Not used: C:\Program Files (x86)\Arduino\libraries\_P170_HLW8012
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
I am not sure you are compiling the ESPEasy in the right way... Why the plugin was installed under the library folder?
Is there a guide on how to install plugins in to the ESP Easy
I am trying to follow this guide,
https://diyprojects.io/esp-easy-install ... brFc8hJZPY
Thanx for that reply
I know a lot of useful services but the best service is cheap insurance quotes online. It helped me a lot!
