[solved] ESPEasyMega on ESP-32
nietbelangrijk
#1 Post by nietbelangrijk » 23 Sep 2017, 14:22
Silly me, see what happens when you have a real bad cold and do not think straight :)
Been trying to flash the Mega version to an ESP-32 WROOM-32
Result is that the ESP will not boot at all.
When I use the Arduino IDE flashing and uploading is no problem and the ESP-32 will boot and execute te program I compiled in the IDE. Using the same parameters in the IDE as on the CLI.
What am I doing wrong?
C:\Users\peter\Downloads\ESPEasy_v2.0.0-dev12>esptool.py -p com4 -b 921600  -c auto write_flash 0x1000 ESPEasy_v2.0.0-dev12_normal_4096.bin
esptool.py v2.1
Connecting........___
Detecting chip type... ESP32
Chip is ESP32D0WDQ6 (revision 1)
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0220
Compressed 566528 bytes to 373377...
Wrote 566528 bytes (373377 compressed) at 0x00001000 in 6.1 seconds (effective 740.1 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting...
Oops, does not work cause the bin file is for esp8266, silly me.
Martinus
Re: ESPEasyMega on ESP-32
#2 Post by Martinus » 23 Sep 2017, 14:32
The bin files are compiled for ESP8266. Doubt if that will work on ESP32...
nietbelangrijk
#3 Post by nietbelangrijk » 23 Sep 2017, 14:36
Martinus wrote: 23 Sep 2017, 14:32 The bin files are compiled for ESP8266. Doubt if that will work on ESP32...
I just realized that.
Will close this posting.
Users browsing this forum: Ahrefs [Bot] and 0 guests
