Config Parameter lost after reboot
HI,
I am starting using ESP Easy. As far as now, I have 4 Nodes working.
Today I have a strange problem:
If I edit the devices in the web mask and they are working but after reboot all the changes are lost and the previous data are back. (i.e. I change che GPIO of a device)
I use a wemos d1 mini .... and firmware version v2.0.0-dev12
Thanks for your help
Re: Config Parameter lost after reboot
We need more infos to help. E.g. config of the device, rules, used controller....
ESPEasy is not build to store device valure to restore previous status on reboot.
It's a feature that coudl come with future release but not in the current one.
e.g. if you have a GPIO=HIGH and you reboot that GPIO will be set to whatever is in the hardware page...
But he can realize this with a retained MQTT message. I have it running this way...papperone wrote: ↑15 Oct 2017, 20:14 ESPEasy is not build to store device valure to restore previous status on reboot.
Me too, but it's not a "out-of-the-box" function and need both a working MQTT broker and some specific setting/rules to make it work...vader wrote: ↑15 Oct 2017, 20:23But he can realize this with a retained MQTT message. I have it running this way...papperone wrote: ↑15 Oct 2017, 20:14 ESPEasy is not build to store device valure to restore previous status on reboot.
I think this is a nice features to be implemented (and I think it was discussed in the Git or somewhere else) but as it shoudl be part of the ESPEasy core it's been targeted for a future release.
As far as i see in his post he edits devices in the web mask and these changes are not stored.
There might be a difference between older and never versions of ESPEasy.
The older versions R1xx stored changes if the "Close" button was clicked.
I've noticed that the ESPEasy-2.0.0 does not store values if "Close" is clicked,
i have to click "Submit" before.
Can not happen to me.....
- shot.jpg (9.27 KiB) Viewed 6765 times
Might be a max flash write exceeded?
Check whether your rx and tx pins are connected together or with any other board...if they are then disconnect them....it should not be a problem afterwards
I don't understand what you all make for a stress with that? From the Winbond data sheet for a W25Qxx:
– Up to 100,000 erase/write cycles
– 20-year data retention
This chips are build-in in a lot of TVs for storing each data. Meaning, each change of the channel or the volume is stored there. And this is very often....
I know But I mean the software limit in the ESP Easy FW. Many times when tinkering with a new unit the 24h limit is exceeded, new users will have a hard time understanding this.
Users browsing this forum: Bing [Bot], Google [Bot] and 91 guests
