I have a problem with the rotary switch:it does not count !
I have connected the two outer pins of the switch (Not a shield with pwr and gnd) to the gpio‘s,configured them ...but no counting at all. Do i have to connect the pins via a resistier to Vcc?
Thx if someone has a hint or workaround .
Ole
Rotary Switch doesn‘t count
Re: Rotary Switch doesn‘t count
A picture or two of your setup would help. Have you rebooted the ESP after the configuration is done (just to be sure)?
ok . yes i did a reboot
What about the rotary encoder? Possible to have a picture/name of it?
And:
Do you need it to be reset by the use of "I"? You can at least try without it.
And:
https://www.letscontrolit.com/wiki/inde ... ry_EncoderDo not use GPIO 16 for this plugin, it will not work properly.
such a type
Great, let's try without the gpio 16 first.
i tried this first - no success
