New ESP gadget
Re: New ESP gadget
Anyone seen Xenon WiFi Touch Switch? It's more expensive than Sonoff Touch...
Re: New ESP gadget
Oh that's great, must have overlooked this one. I hope I can find some spare time the next coming days to give this a try!enesbcs wrote: ↑08 Jul 2017, 08:21I'm looking forward to the testers of plugin 165...renearts wrote: ↑07 Jul 2017, 16:36...
Would love to flash them with ESPEasy, as it is a real delight to work with, and easier to keep all devices around the house on one system.
The most important code regarding the Dual from Espurna seems to be this snippet:
I hope I can find some time somewhere in the next weeks to fiddle a bit around with the dual.![]()
https://www.letscontrolit.com/forum/vie ... 380#p17380
There are also a direct approach of the Sonoff Dual control by bryan:
https://www.letscontrolit.com/forum/vie ... 258#p17196
Re: New ESP gadget
what's the point? more expensive than a sonoff and it requires an external power supply...
Re: New ESP gadget
Thanks for your off topic information.
I now have my pow reporting in to domoticz with your help still lots to learn.
ESPurna works great and I do see the POW as separate to the other sonoff products I'm running.
Life control circuits need to be handled with respect.
Paul V.
Paul V.
costo wrote: ↑03 May 2017, 16:39Did you try to flash the compiled source as it is published by the maker of espurna ?BounceMeister wrote: ↑02 May 2017, 23:10I tried ESPurna, but i can't get it to work on my Sonoff Dual. It fails at the start, while trying to connect.
I'll just forget about this Sonoff stuff. It sounded great, but it's just a disappointment to me now.
Now i have to figure out a way to flash the original firmware back onto it.
You can find all the Sonoff precompiled firmware bin_files here:
https://bitbucket.org/xoseperez/espurna/downloads/
I think it can work on your dual relais or 4 channel relais very well if you follow the right steps.
Now I will go offtopic a little but this is my very positive experience with espurna:
I flashed my Sonoff-POW with Espurna and it works great. I compiled it myself with Atom editer and PlatformIO plugin. I work under linux and followed this guide:
http://www.cnx-software.com/2016/12/03/ ... ss-switch/
In linux or windows:
After flashing you login on 192.168.4.1 , username is admin and password is fibonacci. The first thing the firmware wants you to do is create a new password.
New password needs minimal 8 characters with at least 1 Capital and 1 Number.
Than you enter your own user/pass for your local WiFi network and go to there.
There fill in your MQTT Server_IP and Topic_name (I left topic unchanged).
As I use Domoticz I went to the Domoticz tab on sonoff-pow internal webserver and filled in 5 Idx numbers earlier created in Domoticz as Virtual sensors.
1 Power sensor type: Usage_Electric , registers in Watt
2 Energy_Increment type: Counter_Incremental , registers in kWh (WattHours)
3 Voltage type: Voltage , registers in Volt
4 Current type: Ampere(1 phase) , registers in Ampere
5 Switch type: Switch
Enabled a Domoticz hardware device called: MQTT Client Gateway with Lan Interface. IP is IP of my local RasPi server and the port is 1883. The publish topic i set to ´out +/´ .
You can even calibrate the Sonoff-pow in the webinterface by connecting a known resistive device (lamp or heater) and fill in the measured Watts, Current and Voltage in the Power tab and update these values.
I think Espurna is great software and, as most Sonoff´s are dedicated devices, there is no real need to integrate any of the Sonoff devices in ESPEasy. You can so easy use the precompiled source code from Xose Perez from bitbucket.
Re: New ESP gadget
And with internal power supply? (50x33x22mm)
http://www.ebay.com/itm/AC-220V-Wifi-Re ... EBIDX%3AIT
Re: New ESP gadget
Anyone tried DiFi ESP8266? Seems nice, altough it's price is higher than a Raspberry Pi Zero W.
https://www.aliexpress.com/item/DiFi-ES ... 45026.html
Re: New ESP gadget
Have you look the distance between relay pins (NO/COM/NC) and the ESP pins?enesbcs wrote: ↑10 Sep 2017, 18:47And with internal power supply? (50x33x22mm)
Would you consider have main live so close to the digital pins of the microcontroller? Not me!
Re: New ESP gadget
Good point. What is the appropriate distance according to you?papperone wrote: ↑10 Sep 2017, 21:06Have you look the distance between relay pins (NO/COM/NC) and the ESP pins?enesbcs wrote: ↑10 Sep 2017, 18:47And with internal power supply? (50x33x22mm)
Re: New ESP gadget
In my design I use minimum 15mm or if this is not possible I add a "cut/hole" in between to separate high/low voltage traces...
Re: New ESP gadget
Just in case anyone is running into problems after flashing the new Sonoff S20 plugs (or maybe others as well)
Sonoff flashes as usual, but after reset (plugging in AC) there is now Wifi AP as the device just hangs. New boards are either delivered with ESP8285 or need DOut reset mode.
viewtopic.php?f=4&t=3615&p=20211#p20211
Re: New ESP gadget
Not new, but anyone has tested the followin ESP relay?
https://www.ebay.com/itm/ESP8266-ESP-01 ... 2864309446
It has a greater brother that has a serial MCU between the relay and the ESP-01, but this smaller version (yellow socket, no serial pins) is working similarly?
Re: New ESP gadget
As far as I can see it is 8266 based!enesbcs wrote: ↑20 Nov 2017, 18:19Not new, but anyone has tested the followin ESP relay?
See this one at Banggood:
https://www.banggood.com/search/esp-01s ... odule.html
I think that would take this unit:
https://www.banggood.com/Upgraded-Versi ... rehouse=CN
So the ebay offer is not bad at all!
Re: New ESP gadget
The pictures at banggood are better.. I do not see other MCU, the relay perhaps directly changed by GPIO0 of the ESP-01?manjh wrote: ↑20 Nov 2017, 18:26As far as I can see it is 8266 based!
Re: New ESP gadget
It looks like a very simple device, so I assume you are right.... anyway, the risk is low (only a few Euro's).enesbcs wrote: ↑20 Nov 2017, 18:33The pictures at banggood are better.. I do not see other MCU, the relay perhaps directly changed by GPIO0 of the ESP-01?manjh wrote: ↑20 Nov 2017, 18:26As far as I can see it is 8266 based!
Re: New ESP gadget
Wouldn't be better a Sonoff then?
As far as you need to drive 230VAC load you can't find better deals...
Re: New ESP gadget
I am sure that a Sonoff would be better, but it's size is impressive: 37 x 25mm.
It's in my shopping cart more than an hour, viewing pictures from every angle, thinking about it... then i realize the truth in manjh's post and buy one.
Re: New ESP gadget
I ordered one minutes after I read your post, mainly to see what it can be used forenesbcs wrote: ↑20 Nov 2017, 20:59I am sure that a Sonoff would be better, but it's size is impressive: 37 x 25mm.
It's in my shopping cart more than an hour, viewing pictures from every angle, thinking about it... then i realize the truth in manjh's post and buy one.I'll see what can this be used for.
The argument about Sonoff is valid, but Sonoff has different features.
It is powered directly from 230V, which can be an advantage. On the other hand it can also be a disadvantage if I want to switch anything else than 230V mains.
Also, the Sonoff is bigger. This unit could be easier to build into a device, provided there is a 5V power source available (or enough room to add a small 5V power supply).
So: there is no winner, both devices are different and useful (I hope).
Re: New ESP gadget
I agree there's no winner, I was assuming that if you need to switch AC load, then sonoff is more self-contained and for this other board you need external 5VDC to be supplied (that will make not easy to fit the units, considering as well the power supply).manjh wrote: ↑20 Nov 2017, 22:25I ordered one minutes after I read your post, mainly to see what it can be used for.
Re: New ESP gadget
As an idea, if you need to have the relay on a different purpose than switching mains, one can cut the traces to mains.
Re: New ESP gadget
On a Sonoff you can't, since the power supply for the ESP part is drawn from mains.
On the little device in this topic: you don't need to, since the relay will only be used for switching, so it doesn't really care what is attached.
Re: New ESP gadget
That is exactly what I am trying to point out. You can achieve the same functionality with a Sonoff, you just need to cut the traces connecting mains from input clamps to the relay. Then you can switch anything.
Re: New ESP gadget
Sounds tricky, since you would need to keep the leads to the power supply intact! Remember the ESP part of the Sonoff is powered that way.toffel969 wrote: ↑21 Nov 2017, 16:55That is exactly what I am trying to point out. You can achieve the same functionality with a Sonoff, you just need to cut the traces connecting mains from input clamps to the relay. Then you can switch anything.
Also, you would have to make new connections to the relay.
I think I would rather go for a separate NodeMCU with a relay board, which is effectively just what this small device is.
Re: New ESP gadget
Sure, I got nothing against the small device, and if you buy for the purpose, it is undoutbely better than "open heart surgery" on a sonoff.manjh wrote: ↑21 Nov 2017, 17:06Sounds tricky, since you would need to keep the leads to the power supply intact! Remember the ESP part of the Sonoff is powered that way.
However, often one finds the situation where you just have a sonoff lying around and want to switch "something DC"... then cutting the traces and making a new connection can be an option.
Re: New ESP gadget
I've my own custom made solution, which is way better than sonoff, up to 3 relays and can control anything from 230VAC down to 5VDC
https://www.letscontrolit.com/wiki/inde ... ule3xRelay
It's small enough (80x60 mm) and I just need to design an enclosure fro external use (not top priority as I'm already using many of those inside junction boxes)
PS: it also has a full ESP8266 with 4Mb flash mem and all pinout brough out to pinheaders for easy connection of additional devices (I use those pins for temperature sensors and PIR devices)
Re: New ESP gadget
In deed, this is better. Do you sell your pcb?papperone wrote: ↑21 Nov 2017, 17:44I've my own custom made solution, which is way better than sonoff, up to 3 relays and can control anything from 230VAC down to 5VDC![]()
Re: New ESP gadget
never thought about it, if you are able to assemble it I can share the gerber files but consider all discrete components are SMD...toffel969 wrote: ↑21 Nov 2017, 18:08In deed, this is better. Do you sell your pcb?papperone wrote: ↑21 Nov 2017, 17:44I've my own custom made solution, which is way better than sonoff, up to 3 relays and can control anything from 230VAC down to 5VDC![]()
Re: New ESP gadget
One of the most densly packed esp8266 i ever saw: https://github.com/JanGoe/esp8266-wifi-relaypapperone wrote: ↑21 Nov 2017, 17:44I've my own custom made solution, which is way better than sonoff, up to 3 relays and can control anything from 230VAC down to 5VDC![]()
48x48mm...
I once asked itead for even more densely packed 8266, an micro module. Never heard back from them...
Re: New ESP gadget
I know this design Lisa but IMHO it's too packed with several issues:LisaM wrote: ↑22 Nov 2017, 03:26One of the most densly packed esp8266 i ever saw: https://github.com/JanGoe/esp8266-wifi-relay
48x48mm...
1) the ESP8266 antenna is somehow blocked and I'm certain the quality of WiFi can't be that good
2) GPIO15 pulldown is done without resistor
3) Resistor to the mosfet gate is too big (100K?)
4) No RESET button (and with module connected to MAIN I wonder how you can do it in a safer way
5) CH_PD is pulled high without resistor
6) GPIO0/2 shoudl be pulled high at boot for proper boot
7) GPIO0 is floating and I'm sure this can lead to random issues
8) Relays are driven directly while I believe an optocoupler gives better protection to spikes
9) SDA/SCL signals are not pulled HIGH and this can cause issues with some I2C devices
I'm sure there are other issues but above list is long enough for me to classify this module as "I don't like it"
Re: New ESP gadget
Just cutting traces on mains power lines is not a good idea.toffel969 wrote: ↑21 Nov 2017, 16:55That is exactly what I am trying to point out. You can achieve the same functionality with a Sonoff, you just need to cut the traces connecting mains from input clamps to the relay. Then you can switch anything.
For 230V you need to keep a gap of at least 3 mm or else it could create an arc between the copper lines and thus isn't safe to touch.
Re: New ESP gadget
Sorry for my ignorance but what is the main error with doing it this way? I have an ESP-01 that I'm trying to control my projector with and I pull the CH_PD high with no resistor.
Re: New ESP gadget
Connecting 3V3 directly to a PIN basically you are not limiting the current that can flow, thus you can damage the (delicate!) pin of the ESP8266...grovkillen wrote: ↑22 Nov 2017, 09:56Sorry for my ignorance but what is the main error with doing it this way? I have an ESP-01 that I'm trying to control my projector with and I pull the CH_PD high with no resistor.
I know it's not commonly to happen but, with the cost of a resistor I think it's worth to protect the MC, which is a pain in the a$$ if you need to replace it (talking about ESP-12F)
Re: New ESP gadget
Thanks! I will remember this in future builds
Re: New ESP gadget
On Top:papperone wrote: ↑22 Nov 2017, 10:17Connecting 3V3 directly to a PIN basically you are not limiting the current that can flow, thus you can damage the (delicate!) pin of the ESP8266...grovkillen wrote: ↑22 Nov 2017, 09:56Sorry for my ignorance but what is the main error with doing it this way? I have an ESP-01 that I'm trying to control my projector with and I pull the CH_PD high with no resistor.
GPIO15 needs "low" at startup for booting from the correct memory (GPIO15 = "high" says boot from SD-Card which ist not supported by ESPEasy).
If the ESP is running GPIO15 is a usable GPIO. If you connect GPIO15 directly to GND it can't be used for anything.
It should be possible to connect GPIO15 to GND with a 10 KOhm resistor and with a pushbutton to +3.3V so you can use it as a button input for example.
Just on Bootup the button should not be pressed.
It's same as with GPIO0, just GPIO0 has to be "high" on boot or you'll run into flash mode.
Re: New ESP gadget
If you make it this size, i'll buy ten! https://goo.gl/images/XHULxdpapperone wrote: ↑22 Nov 2017, 07:00I know this design Lisa but IMHO it's too packed with several issues:
2) GPIO15 pulldown is done without resistor![]()
5) CH_PD is pulled high without resistor![]()
I'm sure there are other issues but above list is long enough for me to classify this module as "I don't like it"![]()
Anything (much) bigger then that means it no longer fits and then size no longer matters. It's the reason i still have zwave, all others zwave modules are phased out in favor of esp.
Re: New ESP gadget
That's beyond an hobbysitc approachLisaM wrote: ↑22 Nov 2017, 15:46If you make it this size, i'll buy ten! https://goo.gl/images/XHULxd
I'm sure it's doable, but the investment behind (time and money) won't be affordable if not aiming to a commercial product line...
Re: New ESP gadget
Regrettable, because i am also interested in very small size - european 65mm wall box compatible relays, which i am unable to find.papperone wrote: ↑22 Nov 2017, 17:45That's beyond an hobbysitc approachLisaM wrote: ↑22 Nov 2017, 15:46If you make it this size, i'll buy ten! https://goo.gl/images/XHULxd
Re: New ESP gadget
I'm not familiar with northern EU standard, in Italy the junction boxes are 10x10cm (9x9 internal space) and standard wall plug is 85x55mm so plenty of space
Re: New ESP gadget
I've used several KlikAanKlikUit modules that fint into the wall socket behind a standard switch device. It works, but in my experience the reception is slightly less than the plug-in devices. Probably has something to do with cables and metal (of the switch) taking some of the RF reception away.enesbcs wrote: ↑22 Nov 2017, 19:13Regrettable, because i am also interested in very small size - european 65mm wall box compatible relays, which i am unable to find.papperone wrote: ↑22 Nov 2017, 17:45That's beyond an hobbysitc approachLisaM wrote: ↑22 Nov 2017, 15:46If you make it this size, i'll buy ten! https://goo.gl/images/XHULxd
I'm sure it's doable, but the investment behind (time and money) won't be affordable if not aiming to a commercial product line...I have no intentions to make one on my own, but if something can be hacked easily, i am interested..
So using a small device with an even smaller antenna, that is also partly covered.... not sure! Maybe Wifi signals are not as much hit by this effect.
Re: New ESP gadget
Zwave is using 868MHz, Wifi 2.4GHz. So in theorie wifi should operate better in a wall then zwave due to the shorter wavelength. Zwave is working just fine at my home, so wifi should do better.manjh wrote: ↑22 Nov 2017, 22:26I've used several KlikAanKlikUit modules that fint into the wall socket behind a standard switch device. It works, but in my experience the reception is slightly less than the plug-in devices. Probably has something to do with cables and metal (of the switch) taking some of the RF reception away.
Re: New ESP gadget
The only one i could find is in the link i shared, that is small enough (barely though). Papperone's southern europe's junction boxes are hugh compared to mine (nothern european) boxes, they will never fit.
Re: New ESP gadget
Shorter wavelength depends more on a "line of sight".
Re: New ESP gadget
Re: New ESP gadget
It would take a vertical metal plate to do this kind of shielding, due to the low bandwidth requirements from espeasy an echo would be enough to connect to the ap.
I have three unifi's with overlapping reach sharing the same ssid, so it would still connect to another ap in the case something would block one side. To make it unreachable, you would need to have a faraday cage...
Re: New ESP gadget
I found a very interesting gadget, at first sight i think it is a Sonoff... after zooming in, i saw that "Smart Home" is the brand..
Has someone met it already? Is it ESP based?
https://www.ebay.com/itm/Remote-Control ... 1457073840
Re: New ESP gadget
Seems like a device that could hold an esp8266 inside. For that price it might be worth testing?enesbcs wrote: ↑21 Dec 2017, 18:57I found a very interesting gadget, at first sight i think it is a Sonoff... after zooming in, i saw that "Smart Home" is the brand..Has someone met it already? Is it ESP based?
Re: New ESP gadget
I bet it's a Sonoff-clone, which is funny as now Chinese clone their own productsenesbcs wrote: ↑21 Dec 2017, 18:57I found a very interesting gadget, at first sight i think it is a Sonoff... after zooming in, i saw that "Smart Home" is the brand..Has someone met it already? Is it ESP based?
Re: New ESP gadget
Every successful product is worth copying.
Yes, almost the same price than an ESP Dev Board, but it has a plastic case.grovkillen wrote: ↑21 Dec 2017, 19:08Seems like a device that could hold an esp8266 inside. For that price it might be worth testing?
I hope it's not made with an RTL based chip.. I just ordered one for testing.
Re: New ESP gadget
USD 3.71 for a copy with questionable content and quality vs USD 4.85 for the genuine Sonoff basic (actual price from the Itead.cc website https://www.itead.cc/sonoff-wifi-wireless-switch.html )
Guys, really.....
Have a Merry Christmas everyone
Guys, really.....
Re: New ESP gadget
+1 and Merry Christmas as wellShardan wrote: ↑22 Dec 2017, 12:56USD 3.71 for a copy with questionable content and quality vs USD 4.85 for the genuine Sonoff basic (actual price from the Itead.cc website https://www.itead.cc/sonoff-wifi-wireless-switch.html )
Guys, really.....![]()
