The Things Network LoRaWan plugins to ESP8266 ?
Forum rules
Hi, got so used to the ease of using ESPEasy, but now have use cases for LoRaWAN. How about getting a plugin that will be able to talk to a LoRaWan radio, but have all the ease of working with sensors, mqtt etc in ESP Easy?
Here is a nice example: https://www.thethingsnetwork.org/labs/s ... and-rn2483
Re: The Things Network LoRaWan plugins to ESP8266 ?
Check out Pycom's LoPy.... I got a couple of these on kickstarter, but I haven't had time to look at where the software is yet. This is based on a ESP32 though...
https://www.pycom.io/wp-content/uploads ... tFinal.pdf
There seems to be an option using esp8266 with mysensors firmware and a hope rfm95 chipJR01 wrote: ↑23 Nov 2016, 20:24 Hi, got so used to the ease of using ESPEasy, but now have use cases for LoRaWAN. How about getting a plugin that will be able to talk to a LoRaWan radio, but have all the ease of working with sensors, mqtt etc in ESP Easy?
I still have to start experimenting with lorawan myself. I even dont know if we have it in my area. (North of the nederlands). They seem to have it in amsterdam since 2015?
What if we (the forum) all kick in some money and get you a gateway to play with at home?
https://shop.thethingsnetwork.com/index ... s-gateway/
thanks for the offer. but currently im swamped: still have a lot of open issues that have to be fixed before i want to start working on new stuff.grovkillen wrote: ↑20 Apr 2017, 13:02What if we (the forum) all kick in some money and get you a gateway to play with at home?
Anyone working on ESP8266 and rfm95 or any other lora-chip plugin for the ESP Easy?
Would love to use the ESP Easy for LoRaWAN projects on the TTN network.
Get the device ID to be added to TTN with a link to a wiki in how to create the device.
Select the provisioning type: OTAA or ABP
Enter the required keys from the TTN network.
Send a test-to TTN to see that the module can connect to TTN.
Use the already existing framework for selecting connected sensors
How often to send and wake the device
Once everything is setup the user turn off WiFi since it will drain the battery.
Anyone else think this is a god idea?
Most of the libraries and techniques already exist it just needs to be put together.
I think this would attract a lot of new users and ideas to the community.
There is a great active group of TTN users in Groningen and also a big overlap of members in that group and the "DomoticaGrunn" group.
Too bad I live too far away to connect to the existing LoRaWan network, which means I would have to buy a gateway and setup a network myself.
I am not entirely sure about the use of coupling the ESP8266 to LoRa. The ESP is not really low-power, so that would make long time (years) of battery powered sensors a bit useless.
And also there is really not much bandwidth, so lot of the communications ESPeasy does are not the way LoRa operates.
HiTD-er wrote: ↑17 Jan 2018, 20:10 Too bad I live too far away to connect to the existing LoRaWan network, which means I would have to buy a gateway and setup a network myself.
I do agree in some extent to the battery concerns, BUT: not all sensors need to run on battery. I have a garage, addict and basement where there is no WiFi coverage, would be great to measure humidity and temperature there. (or have a pir to see if someone broke in)
Don't have a LoRaWAN network or gateway, when I bet you have a ESP8266 if you are in this forum
There is a great software and description on how to setup a small 1 channel GW for development and test on this site:
https://github.com/things4u/ESP-1ch-Gateway-v5.0
Just order a "HopeRF RFM9x" of ebay for $7. Make sure you get the right frequency for your region.
Happy hacking
