Change PWM Frequency ?
Whats the easiest way to change PWM Frequency?
Default is 1khz and dimming leds will flickering
I am using ESPEasy_v2.0.0-dev10
Re: Change PWM Frequency ?
I don't see any call to analogWriteFreq in the source.PWM frequency is 1kHz by default. Call analogWriteFreq(new_frequency) to change the frequency.
Thought experiment:
You could try to add a line:
to module:
_P001_Switch.ino
in the section:
case PLUGIN_INIT
as first line
So
case PLUGIN_INIT:
// add this line
analogWriteFreq(5000) //should give 5Khz
// go on with existing code
if (Settings.TaskDevicePin1PullUp[event->TaskI ....
Integration of this function in the GUI by the Dev's, could be an enhancement of (already great!) ESPEasy.
Thank you very much! Are there any instructions how I can compile the source of espeasy?
I want to build
ESPEasy_v2.0.0-dev10_normal_4096.bin
again with changed pwm frequency.
I want to build
See the Wiki:
https://www.letscontrolit.com/wiki/inde ... evelopment
https://www.letscontrolit.com/wiki/inde ... Platformio
Not that complicated ...even I did it
How can you see the led's flickering?
A human doesn't see flickering above 50Hz?
I use PWM on ESP a lot and not 1 is flickering
Gr Ernst
Gr Ernst
I had testet with
no reaction, same result, fan is making noise if it is set under pwm 900
on arduino is no noise with
case PLUGIN_INIT:
// add this line
analogWriteFreq(31300); //should give 31300Hz
void setup() {
TCCR1B = TCCR1B & 0b11111000 | 0x01; // Setzt Timer1 (Pin 9 und 10) auf 31300Hz
- Unbenannt.png (176.63 KiB) Viewed 9723 times
ahlermi wrote: ↑19 Jan 2018, 22:45I had testet with
no reaction, same result, fan is making noise if it is set under pwm 900Code: Select all
case PLUGIN_INIT: { // add this line analogWriteFreq(31300); //should give 31300Hz // go on with existing code
void setup() { TCCR1B = TCCR1B & 0b11111000 | 0x01; // Setzt Timer1 (Pin 9 und 10) auf 31300Hz }
One question, one suggestion:
Question: when you say "on Arduino", do you mean on a physical Arduino, or do you mean an ESP8266 using Arduino IDE
Suggestion: I had the same problem with fan noise, I put a capacitor (rather large) that helped a lot.
I don't think the pwm on ESP has the same quality. Maybe you can use the I2C pwm extender.ahlermi wrote: ↑22 Jan 2018, 17:35physical Arduino
https://we-mod-it.com/board258-diy-do-i ... m-steuern/
Then I suggest you try the solution with a cap, it will smoothen the ripple. Das Pfeifen ist dann zwar auch nicht ganz weg, gefühlt aber 90-95% reduziert, (220µF)
So no changes for fixit via software?
Vote here a thumb up:
in witch way would you build in the capacitor?
pwm + and ground - ?
yes, and you might want to add a resistor too (its then a Low-pass filter) https://provideyourown.com/2011/analogw ... o-voltage/
And that help you??
Yes it reduces the squeaking noise on the fan by about 90%
the result of adding the condensator is that speed is always i think 100%
No, it doesn't make sense to me, nor reflects actual expierience
Meine Lösung
- 3.jpg (551.95 KiB) Viewed 8636 times
- 2.jpg (510.71 KiB) Viewed 8636 times
- 1.jpg (599.96 KiB) Viewed 8636 times
strange that this option is not implemented, as a command.
I think instead of recompiling (which usually breaks things)
I think i will have to add an avr that reads the pwm from the esp and outputs on different frequenccy
Did you see?
https://espeasy.readthedocs.io/en/lates ... hlight=pwm
PWM,<GPIO>,<duty>,<duration>,<frequency>
Hey guys,
i am desperatrly looking for a release which includes working PWM-Frequency settings.
I read that the moving from the GPIO functionality out of the Swith-Module caused some problems, and that this might caused the functionality was removed accidently.
I am happy for any hints in this direction =)
The lastest release:
-duty-cycle is set correctly, but the frequency remains at 1kHz instead the 2.5kHz as in the command
wanted.
The command leads me to this outcome.
I am using to PWM-Power some Fans with that, sadly we can hear the 1kHz, so 20kHz would be nice
PWM,14,250,1000,2500
INIT : Booting version: mega-20190607 (ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
59 : INIT : Free RAM:24960
60 : INIT : Warm boot #6 - Restart Reason: External System
62 : FS : Mounting...
87 : FS : Mount successful, used 75802 bytes of 957314
438 : CRC : program checksum ...OK
475 : CRC : SecuritySettings CRC ...OK
583 : INIT : Free RAM:22160
585 : INIT : I2C
585 : INIT : SPI not enabled
599 : INFO : Plugins: 47 [Normal] (ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3), LWIP: 2.0.3 PUYA support)
hi anyone! i want to change the frequency too
I also found how to change this:
my code rules has the form
pwm,12,100,0,500
but the frequency remains 1 kHz
I am in complete despair((
why the developer gave the instruction and is silent that it is invalid
pwm,12,100,0,500
Try duration to something above 0. Does it work then?
as you can see in my post above it is not working.
I asked you to do a longer interval than zero. Try 1000 as a test.
Ok, I saw your first post now. Sorry. We need to test it ourselves.
Users browsing this forum: Bing [Bot] and 2 guests
