When I use the Optional Settings in the device tab of the BMP085.
I can write %value%-1.1, or %value%/1.1, or %value%*1.1 (1.1 can ofcourse be any other constant)
After submit I will see what I typed in the Formula , %value% and a '-', '/' or '*'
So this works fine.
But when I want to ADD a constant, there is something wrong.
I can type %value%+0.5 but when I click Submit I read %value% 0.5 .......
so the '+' sign does not work, it will not be displyed AND the value will not be added.
I believe it is a bug because i did erase flash and reflashed ESPEasy but the problem persists.
I wonder if I am the only one with this problem.
Formula trouble with BMP085, probably a bug
Re: Formula trouble with BMP085, probably a bug
Could be a bug in earlier versions. Can't reproduce it here using core 2.0.0. and ESP build R51
Are you using ESP core 2.0.0.?
I am using core 2.0.0 but ESPEasy version 48.
I will try to update to R51, i did not find it on sourceforge, there is only R48.
I will try harder to find this R51 release
You can find latest development releases on github only. These sometimes fixes bugs, but could also introduce new ones.
https://github.com/ESP8266nu/ESPEasy
Latest development build is R52.
When I feel that a certain version feels stable, I'll upload the zipfile to SourceForge.
I use this for domoticz to multiply pulse counts to 2. also truing this %Count%/0.5 - also fail
Please help, power meter has 1000 impulses per kwh, i ned 2000 impulses. I use another meter with 2000i/kwh, domoticz set impulses for all meters .
You can only use %value% in formula's, it does not use the 'value name'.
So it should be %value%*2
Currently the total counter is only shown in the webgui for some debugging purposes. It was developed for Domoticz Incremental counters that have only one increment value.
Thank U, i try this.
