I tried several nightlies and the v2.0-20180123 is the last build that works ok; all the later builds are not working well.
The Sonoff boots normally but does not respond to web requests and also seems to loose wifi connection several times. See the serial log below.
The only visible difference between v2.0-20180123 and 24 is the change regarding DST.
And when I fall back to v2.0-20180123 it does not set system time correct, but that may be because of some config change as a result of the new DST.
It is a bit strange, since my 5 NodeMCU's are running fine on the most recent version.
Can it be caused by the difference in flash-size between these boards?
INIT : Booting version: v2.0-20180124
INIT : Warm boot #1
FS : Mounting...
FS : Mount successful, used 76053 bytes of 113201
INIT : Free RAM:25976
INIT : I2C
INIT : SPI not enabled
WIFI : AP Mode disabled
WIFI : AP Mode ssid will be Sonoff-1_21 with address 192.168.4.1
WIFI : Connecting WLAN_WIM attempt #1
Current Time Zone: DST time start: 2018-03-25 02:00:00 offset: 120 minSTD time start: 2018-10-28 03:00:00 offset: 60 min
WIFI : Connected! IP: 192.168.178.241 (Sonoff-1_21)
EVENT: System#Boot
WD : Uptime 0 ConnectFailures 0 FreeMem 22272
EVENT: Clock#Time=Tue,13:37
WD : Uptime 1 ConnectFailures 0 FreeMem 22680
EVENT: Clock#Time=Tue,13:38
WD : Uptime 1 ConnectFailures 0 FreeMem 22240
WD : Uptime 2 ConnectFailures 0 FreeMem 22240
EVENT: Clock#Time=Tue,13:39
WD : Uptime 3 ConnectFailures 0 FreeMem 22208
