Android app for esp easy
Hi, I'm new for home automation. i successfully flash node mcu with ESP Easy . now i want to control it with my android phone via app.so can any one suggest me stable app or method to doing so.
thanks in advance.
thanks in advance.
Re: Android app for esp easy
Best possible approach is to use MQTT as communication and the app MQTT Dash to create a tile design just as you want it.
Well once you have MQTT broker on a local server (RaspberryPi being the cheapest) I'll advice to go for NodeRed which has a very nice extension to easily build up GUI via WebPages not having to know any language (if you are skilled with java and/or angular you can make awesome things then ).
thank you for replay
is it possible that i can use old android phone as local serve with out using RaspberryPi ?
You could try this one:
https://play.google.com/store/apps/deta ... r.com.mqtt
Haven't used it myself though
You do not understand.
I control EasyEsp via the HTTP Request Shortcuts application
https://play.google.com/store/apps/deta ... cuts&hl=pl
It is sensational.
It is sensational.
That's only one way communication though.kniazio wrote: ↑06 Feb 2018, 16:32 You do not understand.
It is sensational.
can anyone give me explanation about how to do this using that app?
is i need to make wifi access point in my phone and connect node mcu to that access point then connect phone into internet via 4g or connect Mcu and phone to my router?
What app specifically are you talking about?
Maybe contact the developer of that app?mahima2md wrote: ↑08 Feb 2018, 07:45 https://play.google.com/store/apps/deta ... r.com.mqtt
this one
Hello, here is a simple and easy to use ESPEasy device controller Android application that i developed for my needs, I hope someone will find it useful.
https://play.google.com/store/apps/deta ... .smarthome
Also, if anyone is interested about the code, feel free to contact me, it's an open project on GitHub and it is following Android best practices(Kotlin/MVVM/Dagger Hilt/Retrofit).
Please give me a Github addressdjakov wrote: ↑11 Nov 2020, 18:09 Hello, here is a simple and easy to use ESPEasy device controller Android application that i developed for my needs, I hope someone will find it useful.
Users browsing this forum: bastler11 and 12 guests
