MQTT-connect event
Micha_he
MQTT-connect event
#1 Post by Micha_he » 08 Mar 2018, 13:03
Is there an event like 'MQTT#Connected' or 'Controller#Connected' ?
I would like to publish a modified/logical-calculated state on boot, but with 'On System#Boot do' the publish is too early (MQTT connect is a moment later) and with a timer the solution is unhappy :(
Re: MQTT-connect event
#2 Post by TD-er » 08 Mar 2018, 13:32
Currently there is no such event, but I think there should be one.
Micha_he
#3 Post by Micha_he » 08 Mar 2018, 14:21
Or alternatively an event like 'System#IsBooted' at the end of the boot-process ;)
I'd like to help and try to add it, but currently the self-compiled images do not work on my PUYA-ESP-01. So I can't test anything on it. :(
fraeggle
#4 Post by fraeggle » 08 Mar 2018, 15:07
I went back to Mega 20180104. In this version the on system#boot do works.
Hope it will be fixed in later releases again
In the ne versions the ESP is also connected to the MQTT with ESP_"MACADRESS" and not with the name given in the SW ex: ESP_TAB4
Peter
Micha_he
#5 Post by Micha_he » 08 Mar 2018, 15:44
Yes, that's maybe a way.
But I need the Vcc-option from the latest firmware for my project. That's the stalemate!
fraeggle
#6 Post by fraeggle » 08 Mar 2018, 17:50
VCC-Option?
What exactly does that mean.
#7 Post by TD-er » 09 Mar 2018, 00:49
I just added a number of new events to be used in rules.
See Pull Request: https://github.com/letscontrolit/ESPEasy/pull/1032
These will be in the next build, which will be made around 5 am (in about 4 hours)
Micha_he
#8 Post by Micha_he » 09 Mar 2018, 14:18
Thanks for that. I'll look at the new version with the additinal events....
Micha_he
#9 Post by Micha_he » 09 Mar 2018, 18:54
Is it possible, that the 'send to controller'-function from the device-categorie, fires the publish before the 'MQTT#Connected'-event ?
#10 Post by TD-er » 09 Mar 2018, 19:29
Micha_he wrote: 09 Mar 2018, 18:54 Is it possible, that the 'send to controller'-function from the device-categorie, fires the publish before the 'MQTT#Connected'-event ?
Yep, that's possible and probably that 'send to controller' event will never reach the MQTT broker, since the controller plugins will stop trying if there is no connection.
Micha_he
#11 Post by Micha_he » 10 Mar 2018, 12:14
Any hint to find the correct position in the ESPEasy sourcecode, where the Function 'Send To Controller' is triggered :?:
#12 Post by TD-er » 10 Mar 2018, 18:28
Controller.ino, the function void sendData(struct EventStruct *event)
Micha_he
#13 Post by Micha_he » 10 Mar 2018, 20:58
I'll see, if I can fix it :)
I often use only the single bootstate-publish of the devices. Afterwards, the ESP goes into deep sleep again. Here you see, what I mean...
That's too high for me ! I don't understand the process with the boot-state-event and the initial publish from it.
I can live with it: Re-publish the state with the MQTT#Connected-event ;)
Micha_he
#14 Post by Micha_he » 12 Mar 2018, 08:14
In my opinion it's, because we have the following init-sequence:
1. PluginInit() (included the _P001_Switch, which try to send the boot-state)
2. WifiConnect
3. MQTTConnect
But how it should be send at Pos. 1 ?
spachal
#15 Post by spachal » 12 Mar 2018, 10:02
TD-er wrote: 09 Mar 2018, 00:49 I just added a number of new events to be used in rules.
Hi, that's really great, THANK YOU, very useful!! :]
Please excuse my English, thanks!
Users browsing this forum: No registered users and 128 guests
