SONOFF S20_EU_V1.3: HowTo DS18B20 and more???
Hello there again...
some days before I get five of the Wallplugs. Flashing the Firmware goes without problems (mega-20180316 1Mb).
I also have disable the RS232 to use the both Pins GPIO1 and GPIO3 i.e. for a DS18B20... Have I doing some wrong to this point? I hope not...
Now I have connect a DS18B20 to GPIO1 (TX) and enter that to "Device > Enviroment -DS18B20", named is "DS-Sensor", enabled it and say to use GPIO-1 (former TX) as Port... But that doesn't work...
If I take a look the deviceadress is empty and the result is 0.00 °C; nothing goes on there... I also have try GPIO-3 (maybe wrong solder) but same=none result...
So where is my mistake there? May anybody like to help me on?
EDIT say:
What I also don't understand is the reaction of the button itselve... The Port (GPIO-1) is pulled up to Ub (Pullup ON) and will be going down while I press the Button... But that isn't what the Firmware see! If I configure "Pullup ON" and "Pushbutton active LOW" similar to the Hardware the Status toggle after every push! That's wrong in my eyes!
EDIT say:
DLzG
Micha
Micha
Re: SONOFF S20_EU_V1.3: HowTo DS18B20 and more???
Just a moment... I just solder one... (time goes by ...)
... Yepp! Works now if I enter "%value% in the formular field ... Thanx a lot... Sometimes things are much to simple to find them
EDIT:
Works for a little while and now shows "nan" and if I take a look the adress are gone and don't comes up again.
Then the thing with the button will be left for solution... Any idea about that?
DLzG
Micha
Micha
See this for better understanding :
https://www.letscontrolit.com/wiki/inde ... noff_Touch
Push button active high will make the relay pull when button is released, push button active low will pull the relay (instantaneously) when button is touched.
... that's what I have say ... But it doesn't work this way. Take a look at the attachement... This config (and also with Active HIGH) create a toogle signal at the button and not a momentary one.
If the Status = 0 and I press the button, the Status goes 1 and stay. If I push the button again, the status goes 0 and stay. That's wrong... Right is: Untouched Button have to be 1 (Pullup and open switch) and have to be 0 if I hold down the button (Switch closed to GND).
- sonoff1.jpg (138 KiB) Viewed 7415 times
DLzG
Micha
Micha
Yes that is what I would think as well. Must be a bug...? Are you able to test on another unit? Don't know how S20 is hardwired, could be that it fix the HIGH on GPIO 0 some other way.
... I will try the other one tomorrow; it's near midnight right now ...
I will also do a messurement with the Scope on the button if the hardware signals are right. But if I'm remember right it's wired simple from Port via Button to GND; makes no sense to do it different ...
The other problem with the DS stay hard... If I take a look with the Scope the Signal on the Dataline stays high all the time. That tell me that the Firmware don't "call" the port for Datarequest. If I create a Reboot there will be also no "hello? Anybody there?". I believe the Call must be every XX seconds similar to the entry I have entered in the DS18B20 - settings at "delay"... But there is nothing...
DLzG
Micha
Micha
... ok, there is no way ... I believe the actual Firmware is buggy...
I have try now four S20 with the actual firmware (ESP_Easy_mega-20180316_normal_ESP8285_1024.bin) and all do it the same way:
Connecting the DS with Pullup at GPIO-1 (TX) or GPIO-3 (RX) after deactivating the RS232. Then enter the 1st time the "Devices / Environment - DS18b20" and the HEX- address comes up and also a temp like 24.55. Just after the 1st try the DS- Device goes to NAN and if I take a look inside the device the HEX address is gone.
I also have connect a Scope on the Dataline. The line is high the whole time that tells me that the ESPeasy- firmware don't poll the port. After a Reboot it looks like a short polling but just a single times... after that it's quite again
DLzG
Micha
Micha
Hmm sounds like you did the impossible and may have found.... <looking around to see nobody is watching> a bug....</>
I've seen more issues with those 1wire sensors.
Not sure about the solution though. Maybe some reset of the bus is needed? Pull-up resistors on the wires?
If no ideas pop up here, please add an issue on the Github.
... some new information:
I think the problem is not directly with the 1wire-query, but is related to the function "delay". If I change the value the polling stops and don't start again, also RESET don't start it again. If I change the value to i.e. 5sec, save it and disconnect the S20 from power, wait a minute and connect it again, the polling starts also. It stops again if I touch the delay- option. Same at all five S20 ...
DLzG
Micha
Micha
Users browsing this forum: Ahrefs [Bot] and 17 guests
