How to make Dew point show on display with sensor BME280?
Hello!
I am using SP Easy, ESP8266 with sensor BME280 and OLED SSD1306. Through the RS232 and the ESP Easy Mega LOG screen, it shows a "dew point". How to make the dew point also appear on the display (OLED SSD1306) and in the json screen?
- COM_Termite.png (5.19 KiB) Viewed 12124 times
Re: How to make Dew point show on display with sensor BME280?
Are you aware of the Wiki?
https://www.letscontrolit.com/wiki/index.php/ESPEasy
and the OLED page?
https://www.letscontrolit.com/wiki/inde ... LEDDisplay
and the OLED page?
Dew point value not presented in devices page.
It's not a value to be used yet I guess. You can do this calculation via formula (example in the rules tutorial section) until it's available through the plugin.
It is a value I've used internal for the BMx280 plugin.
I guess it would be nice to add it as an conversion to be used in rules.
I'm not sure whether other domotica systems can do something with it?
Domoticz does compute it within Domoticz itself.
Thanks for the answers!
I just spotted the dew point in the log too. I would also like to see it as an other value for the device.
Why dev point value is still not available in devices page? That would be important information in controlling air conditioning.grovkillen wrote: ↑01 Apr 2018, 22:04 It's not a value to be used yet I guess. You can do this calculation via formula (example in the rules tutorial section) until it's available through the plugin.
See the bottom of the system variables page (Tools => System variables)
There is an example of how you can compute the dew point using 2 variables.
How can I get things beak to reach / send out the dew point with a bme280 sensor? Unfortunately, only the air pressure, humidity, temperature is displayed. my attempts so far have failed.
Dew point(T,H):thesstozteron wrote: ↑24 Apr 2021, 21:53 How can I get things beak to reach / send out the dew point with a bme280 sensor? Unfortunately, only the air pressure, humidity, temperature is displayed. my attempts so far have failed.
%c_dew_th%(18.6,67) => 12.31
%c_dew_th%([bme#T],[bme#H])
Users browsing this forum: Bing [Bot] and 121 guests
