Wemos D1
Re: Wemos D1
The website says it can be programmed with the ESP-Arduino IDE, so you can flash ESPEasy on it.
Re: Wemos D1
I have 2x Wemos D1 and 1x Wemos D1 Mini and also the end-of-life Wemos Lolin. All running fine
![Lach :-)](./images/smilies/icon_e_smile.gif)
Re: Wemos D1
Mine are on on toll aéroport, Christmas time, toll are long
Just read that those are compatible with nodemcu code since 03 Décembre 2015
Re: Wemos D1
When you flash ESPEasy on this thing the NodeMCU firmware will be overwritten/erased so compatibility is not important I think.Deennoo wrote:Mine are on on toll aéroport, Christmas time, toll are long
Re: Wemos D1
ok thanks, wainting to get it !
Re: Wemos D1
As I use the Arduino environment (also the new 2.0 release on 1.6.5), I can confirm this works perfectly. Also it auto sets program mode, very easy
. You just hit upload, no need to reset and pull up/down some GPIO's.
Re: Wemos D1
Recieve today 5 x Wemos D1 Mini + dht shield
After solding pin, and loading ESPEasy b 58 on It, that run fast ! and looks stable, lets see the futur.
On mini i had to put d3 to gnd to enter on uploading mode.
Re: Wemos D1
DHT11 or DHT22?
Over which GPIO Pin the DHT is connected? Can you post a screen from ur Device Config?
Thx
Thx
Re: Wemos D1
Hi, I can confirm D! by Wemos works fine, have latest version on and works pretty well, btw I have ordered few of these breadboards so if you need something for quick prototyping
http://www.aliexpress.com/item/Free-shi ... 19368.html
