ESPFinder
enesbcs
ESPFinder
#1 Post by enesbcs » 09 Apr 2018, 21:20
ESP Easy Netscan is a very nice and handy application, thanks to grovkillen..
It's too bad, is just for Windows, so i stealed the idea, and made a simpler looking version in Python3 to Linux fans, like me. :)
ESPFinder first beta:
Screenshot
Source code:
https://github.com/enesbcs/espfinder-python
Re: ESPFinder
#2 Post by grovkillen » 09 Apr 2018, 21:22
Happy to have inspired :D
AndrewJ
Re: ESPFinder
#3 Post by AndrewJ » 10 Apr 2018, 09:02
Thanks enesbecs and grovkillen,
I'm also a Linux user, I will give it a try!
Thanks for sharing.
Andrew
sentinel
Re: ESPFinder
#4 Post by sentinel » 21 Apr 2018, 17:07
I tried installing espfinder, but I'm getting errors when executing "sudo pip3 install multiprocessing ctypes itertools contextlib". The error is:
Command "python setup.py egg_info" failed with error code 1
Do you know what am I missing? :?
enesbcs
Re: ESPFinder
#5 Post by enesbcs » 21 Apr 2018, 18:48
sentinel wrote:
21 Apr 2018, 17:07
I am using Ubuntu Linux 16.04 with latest stable Python 3.5.2 from ubuntu repositories with pip 8.1.1.
Maybe you can try to upgrade pip:
sudo python -m pip install --upgrade pip
sudo pip3 install --upgrade setuptools
sentinel
Re: ESPFinder
#6 Post by sentinel » 22 Apr 2018, 21:05
Thanks for your reply. I tried what you proposed - I have the latest versions (the message I get is "Requirement already up-to-date"). I have python 3.5.2 and pip 10.0.1.
The installation of "multiprocessing" fails.
There is something in my installation which is outdated or missing.
micropet
Re: ESPFinder
#7 Post by micropet » 22 Apr 2018, 22:49
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-663zc296/multiprocessing/
enesbcs
Re: ESPFinder
#8 Post by enesbcs » 23 Apr 2018, 07:23
Maybe multiprocessiong is already installed in a non-pip way which can not be overwritten by pip.
Try to reinstall stdlib:
sudo apt-get install --reinstall libpython3.5-stdlib
sentinel
Re: ESPFinder
#9 Post by sentinel » 23 Apr 2018, 20:52
I downloaded multiprocessing-2.6.2.1.tar.gz and the INSTALL.txt says: "Python 2.6 and newer versions already come with multiprocessing."
When trying to install it (using sudo pip3 install multiprocessing) the error I get is:
      File "<string>", line 1, in <module>
      File "/tmp/pip-install-vw9qsdn_/multiprocessing/setup.py", line 94
        print 'Macros:'
    SyntaxError: Missing parentheses in call to 'print'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-vw9qsdn_/multiprocessing/
It seems like the error is that print cannot be followed by ' (single quote) in python3. It has to be "
I also checked in /usr/lib/python3.5 and I have: ctypes, multiprocessing. When I try to execute:
sudo pip3 install itertools
I get the message:
Collecting itertools
Could not find a version that satisfies the requirement itertools (from versions: )
No matching distribution found for itertools
I get a similar message with sudo pip3 install contextlib
Can we somehow compare our installations?
enesbcs
Re: ESPFinder
#10 Post by enesbcs » 24 Apr 2018, 07:06
sentinel wrote:
23 Apr 2018, 20:52
Can you try to run espfinder.py? I think all prerequisites already satisfied, and nothing left to install.
sentinel
Re: ESPFinder
#11 Post by sentinel » 24 Apr 2018, 20:46
Thanks again for your reply. I'm afraid it doesn't work :(
The GUI starts but nothing is displayed. And when I click on "Refresh", I get a lot of errors:
Process Process-1:
Process Process-2:
  File "/usr/lib/python3.5/multiprocessing/process.py", line 249, in _bootstrap
    self.run()
  File "/usr/lib/python3.5/multiprocessing/process.py", line 93, in run
    self._target(*self._args, **self._kwargs)
  File "espfinder.py", line 35, in pinger
    hostadrr = self.ownip.split('.')[:-1]
AttributeError: 'bool' object has no attribute 'split'
Process Process-3:
    self.run()
Similarly with the console version
enesbcs
Re: ESPFinder
#12 Post by enesbcs » 25 Apr 2018, 19:42
sentinel wrote:
24 Apr 2018, 20:46
This means, that the python program are unable to determine your machine local address from the "ifconfig" command output. Can you share the output of ifconfig?
I will have to implement some basic error messages... :)
sentinel
Re: ESPFinder
#13 Post by sentinel » 25 Apr 2018, 20:57
yes, here it is:
$ ifconfig
enp11s0   Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:17
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:4544 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4544 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:423546 (423.5 KB)  TX bytes:423546 (423.5 KB)
virbr0    Link encap:Ethernet  HWaddr 00:00:00:00:00:00
          inet addr:192.168.122.1  Bcast:192.168.122.255  Mask:255.255.255.0
wlp2s0    Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: xxxx::xxxx:xxxx:xxxx:xxxx/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1311175 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1506516 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:541416351 (541.4 MB)  TX bytes:1555227741 (1.5 GB)
enesbcs
Re: ESPFinder
#14 Post by enesbcs » 25 Apr 2018, 23:30
sentinel wrote:
25 Apr 2018, 20:57
yes, here it is:
enp11s0
virbr0
wlp2s0
I think i get it, i expected eth0-9 and wlan0-9. :) Fixed, and uploaded to github.
sentinel
Re: ESPFinder
#15 Post by sentinel » 26 Apr 2018, 21:21
Thanks! It works :)
Can I ask something:
when I start the gui, it shows nothing. After I click on Refresh, I get the list of devices. Is this normal?
Thanks again for the implementation and your support!
enesbcs
Re: ESPFinder
#16 Post by enesbcs » 26 Apr 2018, 23:44
sentinel wrote:
26 Apr 2018, 21:21
Thanks! It works :)
You are welcome. :) Yes the need to click on Refresh is by design, but in the future it can be change.. but first i have to implement some sort of progress feedback. Since i using multiprocessing for fast pinging it is hard to sync a global variable in the main app. :)
Also developed some sort of Windows compatibility, just for fun, but it is slow as hell.
sentinel
Re: ESPFinder
#17 Post by sentinel » 27 Apr 2018, 19:59
excellent 8-)
