It's too bad, is just for Windows, so i stealed the idea, and made a simpler looking version in Python3 to Linux fans, like me.
ESPFinder first beta: Source code:
https://github.com/enesbcs/espfinder-python
I am using Ubuntu Linux 16.04 with latest stable Python 3.5.2 from ubuntu repositories with pip 8.1.1.
sudo python -m pip install --upgrade pip
sudo pip3 install --upgrade setuptools
File "<string>", line 1, in <module>
File "/tmp/pip-install-vw9qsdn_/multiprocessing/setup.py", line 94
print 'Macros:'
SyntaxError: Missing parentheses in call to 'print'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-vw9qsdn_/multiprocessing/
Can you try to run espfinder.py? I think all prerequisites already satisfied, and nothing left to install.
Process Process-1:
Process Process-2:
File "/usr/lib/python3.5/multiprocessing/process.py", line 249, in _bootstrap
self.run()
File "/usr/lib/python3.5/multiprocessing/process.py", line 93, in run
self._target(*self._args, **self._kwargs)
File "espfinder.py", line 35, in pinger
hostadrr = self.ownip.split('.')[:-1]
AttributeError: 'bool' object has no attribute 'split'
Process Process-3:
self.run()
This means, that the python program are unable to determine your machine local address from the "ifconfig" command output. Can you share the output of ifconfig?
$ ifconfig
enp11s0 Link encap:Ethernet HWaddr xx:xx:xx:xx:xx:xx
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:17
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4544 errors:0 dropped:0 overruns:0 frame:0
TX packets:4544 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:423546 (423.5 KB) TX bytes:423546 (423.5 KB)
virbr0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
inet addr:192.168.122.1 Bcast:192.168.122.255 Mask:255.255.255.0
wlp2s0 Link encap:Ethernet HWaddr xx:xx:xx:xx:xx:xx
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: xxxx::xxxx:xxxx:xxxx:xxxx/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1311175 errors:0 dropped:0 overruns:0 frame:0
TX packets:1506516 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:541416351 (541.4 MB) TX bytes:1555227741 (1.5 GB)
I think i get it, i expected eth0-9 and wlan0-9.
You are welcome.
Users browsing this forum: Bing [Bot] and 5 guests
