I've been working on a smoke Sensor
It uses two types of smoke sensors
MQ9+MQ135(carbon monoxide +smoke)
These give analogue and digital outputs
(only issue in domoticz there is no dedicated dummy device, air quality doesn't work, so currently being logged as a percentage)
It also has a temp /Hum, Pir and lux sensors
See link to YouTube
https://youtu.be/ze3ho06KZDg
Smoke Sensors
Re: Smoke Sensors
by the way. does anyone know how show switched inputs as 1 or 0 rather than 1.00 or 0.00 many thanks?
Re: Smoke Sensors
Hi hamster,hamster wrote:Hi
See link to YouTube
Can you please explain a little bit more the wiring of the MQ135 sensor to the ESPEasy and your Domoticz settings for it?
Thank you!
p.s. Liked your project video on YouTube!
Re: Smoke Sensors
How did you connect those sensors? You have only one T Out pin.hamster wrote:Hi
See link to YouTube
I want to connect MQ-2 with esp-01 nad want to measure the gas or smoke level.
Re: Smoke Sensors
Anybody can share ESPeasy plugin code for MQxxx devices?
