Wemos D1 mini pro. Not enough space using OTA?
I have done compiled and flashed Wemos D1 mini pro with 15MB SPIFFS.
Sketch size is about 634kB.
Now I had update using OTA and I have not enough space. Why?
Were the bin file is loaded using OTA ? To RAM? Or SPIFFS is too large?
Sorry for the basic questions but I'm rookie lamer.
Re: Wemos D1 mini pro. Not enough space using OTA?
What was the first version, the 1MB one? If you flashed that one the FW will think that the available space is that if an 1MB.
Previous version is 15MB I want to upgrade new 15MB on an old 15MB. Compiled on Arduino using "Wemos D1 mini pro" from menu.
Latest sources and core 2.4.1
Build
20102 - Mega (ESP82xx Core 2_4_1, NONOS SDK 2.2.1(cfd48f3))
GIT version
xuryV0.1
Plugins
47 [Normal]
Build time
Apr 30 2018 18:28:16
Binary filename
ESPEasy.ino.bin
Storage
Flash Chip ID Vendor: 0xC8 Device: 0x4018
Flash Chip Real Size: 16384 kB
Flash IDE Size: 16384 kB
Flash IDE speed: 40 MHz
Flash IDE mode: DIO
Flash Writes 0 daily / 66 boot
Sketch Size 661 kB (360 kB free)
So it's a self compiled bin. What size did you compile it for? I suspect 1024...
You should have compiled "normal_4096"
Or better still, use the official build.
I selected from tools/boards "Wemos D1 mini pro" It has only to choose 15MB SPIFFS.
I thought that having 15MB spiffs would not be problems with OTA
Formatting after flashing takes a lot of time. So I think that SPIFFS is proper created.
Perhaps mega sources still does not support size more than 4MB?
The build you chose is not an official build setup made by us and we cannot guarantee that is works. We do not support 4096+ SPIFF sizes but you can use the 4096 build on larger SPIFFs with no problem. It will allocate only 4096 bytes of the 16MB.
Okay. Now everything is clear. Thanks.
