ESP-32 plans for ESPEasy (?)
Tommmii
Re: ESP-32 plans for ESPEasy (?)
#51 Post by Tommmii » 15 Apr 2018, 10:44
what's the best place to watch, to know if there's a fresh build ?
Right now i'm watching https://www.letscontrolit.com/wiki/index.php/ESPEasy32
#52 Post by TD-er » 15 Apr 2018, 12:30
There are plans to include it in the nightly build. Not sure about the status.
hamster
#53 Post by hamster » 16 Apr 2018, 19:25
TD-er wrote:
14 Apr 2018, 20:34
hamster wrote:
14 Apr 2018, 19:12
Latest esp32 version http://www.letscontrolit.com/downloads/ ... R20100.zipseems very good and quite stable.
I was wondering how to compile a version myself as I want to add a sensor [Nextion display] from the playground
I tried and managed to create one in PlatformIO but the result only had a few devices available and not the nextion.
Any assistance much appreciated.
The Nextion plugin is on its way, so have a little patience. :)
looking forward to it :D
hamster
#54 Post by hamster » 29 Apr 2018, 00:35
any pointers how to compile a image for esp32 ?
fazambuja
#55 Post by fazambuja » 29 Apr 2018, 23:56
You can do it with Platformio IDE. It will show up on the list of what can you build. The number of plugins included is really minimal, you need to include the ones you want and test. But first, try to build and upload the firmware :)
https://www.letscontrolit.com/wiki/inde ... Platformio
https://www.letscontrolit.com/wiki/inde ... platformio
Tommmii
#56 Post by Tommmii » 30 Apr 2018, 10:54
@hamster : if you do have a successful build, would you mind sharing the files to flash ?
hamster
#57 Post by hamster » 02 May 2018, 23:58
within Platformio I can build esp32dev
However i end up with an image with only a few devices
So being a novice and not knowing how to select the devices for the build I edited the Framed OLED 36 device added the Nextion content, renaming all references to 75 to 36
but this then fails when compiling with the following errors? Any ideas?
Linking .pioenvs\esp32dev\firmware.elf
.pioenvs\esp32dev\src\ESPEasy.ino.cpp.o:(.literal._Z10Plugin_036hP11EventStructR6String+0x34): undefined reference to `ESPeasySoftwareSerial::ESPeasySoftwareSerial(unsigned char, unsigned char, bool, unsigned short)'
.pioenvs\esp32dev\src\ESPEasy.ino.cpp.o:(.literal._Z10Plugin_036hP11EventStructR6String+0x38): undefined reference to `ESPeasySoftwareSerial::begin(long)'
.pioenvs\esp32dev\src\ESPEasy.ino.cpp.o: In function `StringSumHelper::StringSumHelper(String const&)':
C:\Users\noobed\.platformio\packages\framework-arduinoespressif32\cores\esp32/WString.h:47: undefined reference to `ESPeasySoftwareSerial::ESPeasySoftwareSerial(unsigned char, unsigned char, bool, unsigned short)'
.pioenvs\esp32dev\src\ESPEasy.ino.cpp.o: In function `Plugin_036(unsigned char, EventStruct*, String&)':
C:\Users\noobed\.platformio\packages\framework-arduinoespressif32\cores\esp32/WString.h:47: undefined reference to `ESPeasySoftwareSerial::begin(long)'
collect2.exe: error: ld returned 1 exit status
*** [.pioenvs\esp32dev\firmware.elf] Error 1
#58 Post by TD-er » 05 May 2018, 00:04
The list of devices included in the ESP32 build is very limited, because the rest does not yet work very well (or not at all) on ESP32.
I just added a few that work and others will follow, but lately there have so many issues with the 82xx builds, that took all my time to fix.
whatsupskip
#59 Post by whatsupskip » 13 Jul 2018, 00:35
I couldn't flash my ESP-32, but given the development is still in its early days I won't worry about it.
I am very grateful for all the work by the developers on the ESP8266 version of the ESPEasy.
Users browsing this forum: dynamicdave and 45 guests
