Post
by grovkillen » 22 Dec 2017, 14:33
papperone wrote: ↑22 Dec 2017, 13:59
+1 and Merry Christmas as well
+1
manjh
#302
Post
by manjh » 22 Dec 2017, 15:14
no-brainer.
Merry x-mas to all!
#303
Post
by Shardan » 22 Dec 2017, 18:13
Always remember Ruskin's rule:
"There is hardly anything in the world that someone cannot make a little worse and sell a little cheaper, and the people who consider price alone are that person's lawful prey. It's unwise to pay too much, but it's worse to pay too little. When you pay too much, you lose a little money – that is all. When you pay too little, you sometimes lose everything, because the thing you bought was incapable of doing the thing it was bought to do. The common law of business balance prohibits paying a little and getting a lot – it can't be done. If you deal with the lowest bidder, it is well to add something for the risk you run, and if you do that you will have enough to pay for something better."
(John Ruskin)
enesbcs
Post
by enesbcs » 22 Dec 2017, 18:31
I have already a Sonoff S20 and a Sonoff Dual, and honestly i do not need either the genuine Basic, neither the clone, there are no place of use currently to me. It will go straight to the bottom of a shelf, after i tested it, i am only curious.
I need to know what it is made of.
Merry Christmas!
enesbcs
Post
by enesbcs » 01 Feb 2018, 19:31
You mean 3.71$ + Free international shipping vs 4.85$+25$ shipping? Just joking, i know that on ebay original Sonoff basic can be found for 6$ with FREE SHIPPING.. but as i heared a lot of ebay seller sends replacement Powstro models nowadays.
In the meantime i received this "SmartHome" branded item, and when i tear it apart i see that it contains exactly the same hardware as the Powstro Basic.
ESP8266-S3 flashed by me immediately, and i played some time.
#306
Post
by Shardan » 02 Feb 2018, 10:29
... with thin copper tracks and other flaws...
enesbcs
Post
by enesbcs » 03 Feb 2018, 22:28
manjh wrote: ↑20 Nov 2017, 19:02
enesbcs wrote: ↑20 Nov 2017, 18:33
The pictures at banggood are better.. I do not see other MCU, the relay perhaps directly changed by GPIO0 of the ESP-01?
It looks like a very simple device, so I assume you are right.... anyway, the risk is low (only a few Euro's).
In the meantime this device arrived, sadly it's ESP-01S based on PUYA, but can be flashed with R147. The relay controlled by GPIO0 directly. GPIO2 did not do anything except lightning the ESP-01S blue LED.
manjh
#308
Post
by manjh » 26 Feb 2018, 17:28
enesbcs wrote: ↑03 Feb 2018, 22:28
How did you flash it? I connected the ftdi in the usual manner, crossing tx and rx.
Connected GPIO0 to gnd.
Plugged in and found COM3.
Tried to load R147 4096 using the esptool, but it will not load. (also tried 1024)
What am I missing?
enesbcs
Post
by enesbcs » 26 Feb 2018, 17:41
manjh wrote: ↑26 Feb 2018, 17:28
What am I missing?
I connected it with this way:
Than flashed with R147 1Mb/64k SPIFFS version at DOUT mode with the new Nodemcu PyFlasher application at ttyUSB0 (Linux).
manjh
#310
Post
by manjh » 27 Feb 2018, 12:04
enesbcs wrote: ↑26 Feb 2018, 17:41
What am I missing?
I carefully reconnected following your diagram and ran Py Flasher in DOUT mode, loading R147 1024.
It starts with "Connecting....._____....." but after a while simply stops. No error message, nothing.
Also noticed that the blue LED does not blink, as it usually does on an ESP module during load.
After this I disconnected the wiring and started the unit on 3.3V and Gnd alone, and see the FaryLink AP showing up on Wifi. Looks like nothing was loaded...
Any ideas?
Post
by grovkillen » 27 Feb 2018, 12:09
Probably never got booted into flash mode.
manjh
#312
Post
by manjh » 27 Feb 2018, 12:26
grovkillen wrote: ↑27 Feb 2018, 12:09
I thought that as well. So I double-checked all connections.
Also, when I start the unit without GPIO0 connected to ground, I can see the blue LED flash twice quickly. When I start the unit with GPIO0 low, it only blinks once. So there definitely is a difference...
toffel969
#313
Post
by toffel969 » 27 Feb 2018, 13:15
Shardan wrote: ↑22 Dec 2017, 18:13
(John Ruskin)
The long version of the good old German saying "Wer billig kauft, kauft zwei mal", --> If you buy cheap, you buy twice. I concur
manjh
#314
Post
by manjh » 27 Feb 2018, 13:26
toffel969 wrote: ↑27 Feb 2018, 13:15
(John Ruskin)
You run into a tricky area considering the definition of the word "cheap".
Expensive: a 25000 Euro car that depreciates 40% in the first year.
Cheap: a 35000 Euro car that depreciates 20% in the first year.
I've seen examples of both. My point: price alone does not determine if a product is cheap or expensive.
Especially with the quickly dropping prices of Chinese hardware, it makes sense to keep an eye on new items and check them out.
enesbcs
Post
by enesbcs » 02 Mar 2018, 23:08
I've found a very nice looking 27x19x18mm sized ESP8266 module with one relay and one touch button.
https://www.ebay.com/itm/ESP8266-WIFI-I ... 1932199168
I currently using Sonoff Touch and Sonoff T1 for Lighting Control, so i do not see any use case for me, but still it is a very compact unit. Maybe for a smart smart 230V extension cable..
But as i see the RX and TX is near the crystal and not an easy task to solder it.
enesbcs
Post
by enesbcs » 05 May 2018, 17:08
I found a new device, looks like a redesigned Sonoff S20..
"WAZA Wifi Smart EU Plug Power Socket"
Anyone has it? I wonder if it could be flashed?
enesbcs
Post
by enesbcs » 30 May 2018, 23:55
enesbcs
Post
by enesbcs » 13 Sep 2019, 17:39
Prutsium
#322
Post
by Prutsium » 15 Sep 2019, 12:48
Cool one
You get also quite a lot of additional sensors.
Might be funny playground for making door entry keypad with display
tim
#323
Post
by tim » 15 Sep 2019, 15:25
Does ESP Easy support the display?
enesbcs
Post
by enesbcs » 15 Sep 2019, 15:35
tim wrote: ↑15 Sep 2019, 15:25
The display is an SPI connected ST7789V so i guess not.
