Custom firmware problem
im trying to create a esp mega firmware with this modul
https://github.com/letscontrolit/ESPEas ... usW266.ino
what I've done so far:
downloaded the whole pack, and downloaded the _P046_VentusW266.ino and put it into
the /src folder
then I've used atom to build it like it says in this guide
https://www.letscontrolit.com/wiki/inde ... platformio
but when I upload it, the ventus dont show up, in the end of the guide there is something I dont get
I've added the screenshot, could that be the thing im missing ?
the /src folder
- Screen Shot 2018-05-04 at 15.03.35.png (30.43 KiB) Viewed 4542 times
"Don't let hope become a memory"
Re: Custom firmware problem
Sorry, old info. You need to move the plugin to the stable list found here:
https://github.com/letscontrolit/ESPEas ... gin_sets.h
um.... now im even more lost
its not my plugin, but an exsisting one
could u tell more specific what I need to do ?
You download the zip (green button on the main GitHub page) and just edit this file:
define_plugin_sets.h
In which you move the plugin name to the list where the rest of the stable plugins are found.
hm
added the file _P124_Ventus_W266_RFM69.ino to /src
in define_plugin_sets.h, #define USES_P046 // W266 but still no show!
- Screen Shot 2018-05-04 at 18.41.33.png (71.01 KiB) Viewed 4514 times
shall i use another firmware instead of normal?
You shouldn't need to add anything except change that one file. P046 is already there in the src folder.
ok im kinda lost, if I open define_plugin_sets.h from fresh and look in
line 449 and 450 :
#ifdef PLUGIN_SET_EXPERIMENTAL
#define USES_P046 // VentusW266
then its already there? but I can't see it,
line 449 and 450 :
You need to cut that row and place it under NORMAL (as of now it's under the EXPERIMENTAL definition).
Ok putted it in
// STABLE #####################################
and compiled it, still it dont show up
heres my define_plugin_sets.h
https://hastebin.com/afowokavac.cpp
- Screen Shot 2018-05-05 at 12.00.10.png (70.53 KiB) Viewed 4456 times
What did you compile, build normal?
You should really remove a lot of the other plugins to have enough memory left. You really don't need other plugins since that plugin is really specific to that weather station.
Can you make a list of things required for that weather station?
And also the ESP type + size of flash memory.
Is that a custom built setup, or is commercially available?
It's available on Conrad.com as a renkforce product. Only generic categories and the W266 plugin is needed I believe.
If you have a more descriptive text, I could add it as a pre-defined set to build.
P003 NORMAL Generic P003_Pulse.ino
P026 NORMAL Generic P026_Sysinfo.ino
P033 NORMAL Generic P033_Dummy.ino
P037 NORMAL Generic P037_MQTTImport.ino
P046 TESTING Hardware P046_VentusW266.ino
https://www.letscontrolit.com/wiki/index.php/VentusW266
Plus P001
Did you do a clean before re/compile ?
im kinda lost now Oo
could u sent an example file ?
I assume you're using an ESP8266 with 1M flash?
Or is it 4M?
I will now add this version to the PlatformIO setup, so you can make a build of newer versions.
Or is it 4M?
Could you try this build? https://www.dropbox.com/s/0f3lhz4chr4nn ... 6.rar?dl=0
im totally blank, dont know what u mean??
can't test it now, my MacBook Air won't connect to esp at all, so gone try when im back at the Mac mini
i couldn't be more happy, my parents it gonna love it
sooooo many tnx, but that did i do wrong ?
- Screen Shot 2018-05-07 at 19.50.36.png (103.34 KiB) Viewed 4726 times
You can see the changes I made over here:
https://github.com/letscontrolit/ESPEas ... 1378/files
Who is responsible for this plugin?
the rain sensor isn't listed, and i can't get it to report inside temp / humidity to the mutt
- Screen Shot 2018-05-08 at 11.57.06.png (28.01 KiB) Viewed 4702 times
- Screen Shot 2018-05-08 at 11.56.47.png (131.99 KiB) Viewed 4702 times
Justme-nl is the writer of the online guide and I believe that he's the one who first created this plugin. I don't own a Ventus W266/RenkForce W205GU so I cannot fix this myself. Maybe someone else can? And I wouldn't say that "someone" is responsible for this, we're all in this together
yar thats why we are help ;D will glady help others to
but are u sure about the name ? Justme-nl i can't find him
I’m not 100% but I think I did read in the plugin readme Tint and RHint are not “interfaced” to the plugin due to hardware reasons.
For the rain maybe read more of the project data, as I changed course I stopped my interest in the W266
yar read that after, and got the rain and outside temp enabled
hope they can fix the in temp to
Help,
I do not get displayed values, have no idea where the problem could be. In the log you can see that there is a connection!
i am using an esp8266 notemcu, is there anything functional to install?
3931717: WD : Uptime 66 ConnectFailures 0 FreeMem 21536 WiFiStatus 3
3961717: WD : Uptime 66 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
3991717: WD : Uptime 67 ConnectFailures 0 FreeMem 23224 WiFiStatus 3
4021717: WD : Uptime 67 ConnectFailures 0 FreeMem 21728 WiFiStatus 3
4051717: WD : Uptime 68 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4081717: WD : Uptime 68 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4111717: WD : Uptime 69 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4141717: WD : Uptime 69 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4171717: WD : Uptime 70 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4201717: WD : Uptime 70 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4231717: WD : Uptime 71 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4261717: WD : Uptime 71 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4291717: WD : Uptime 72 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4321717: WD : Uptime 72 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4351717: WD : Uptime 73 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4381718: WD : Uptime 73 ConnectFailures 0 FreeMem 22520 WiFiStatus 3
4385549: Ventus W266 Rcvd(00:00:00) 7FB1:60:1B:C40000D400:03:00000000:880000:12:3FB1:0000D9 > EE
4411717: WD : Uptime 74 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4416549: Ventus W266 Rcvd(00:00:00) 7FB1:60:1A:D40000D400:03:00000000:800000:01:3FB1:000197 > C2
4441718: WD : Uptime 74 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4447549: Ventus W266 Rcvd(00:00:00) 7FA1:60:1A:9C0000D400:03:00000000:880000:10:3FB1:0000D9 > C5
4471718: WD : Uptime 75 ConnectFailures 0 FreeMem 23416 WiFiStatus 3
4478550: Ventus W266 Rcvd(00:00:00) 7FB1:40:1A:F40000D400:03:00000000:880000:12:3FB1:0000D9 > 36
- 3.JPG (53.54 KiB) Viewed 1440 times
- 2.JPG (85.1 KiB) Viewed 1440 times
- 1.JPG (72.46 KiB) Viewed 1440 times
I have no experience myself with this plugin.
But considering the labels of the GPIO functions, it looks like it is using SPI.
The pins you're showing in your config are not the pins connected to the hardware SPI in the ESP.
Signal IO index ESP8266 pin
HSPI CLK 5 GPIO14
HSPI /CS 8 GPIO15
HSPI MOSI 7 GPIO13
HSPI MISO 6 GPIO12
See: https://nodemcu.readthedocs.io/en/master/modules/spi/
I would suggest to reconnect your device to these pins. I have not looked at the code of that plugin, so I'm not sure if the code does try to address the hardware SPI. (your mileage may vary so to speak)
HSPI CLK 5 GPIO14
HSPI /CS 8 GPIO15
HSPI MOSI 7 GPIO13
HSPI MISO 6 GPIO12
I tested, unfortunately, nothing helped.
In the log, data arrives, but nothing is displayed. Everything stays at 0. Perhaps something has been changed by the manufacturer. With the app USES_P124 have the same result or worse, it does not do anything in the log!
854305: Ventus W266 Rcvd(00:00:00) 7FB0:57:1A:EF0000EE00:0F:00004C00:880000:12:3FB0:010076 > D2
83950: Ventus W266 Rcvd(16:22:43) 7FB1:58:1A:E50000E400:01:02003600:980000:12:3F31:0100CB > EF
Data stays at 0
Data stays at 0
- 5.JPG (92.07 KiB) Viewed 1396 times
- 4.JPG (92.31 KiB) Viewed 1396 times
You are running multiple instances of the plugin.
Not sure if that plugin is capable of handling multiple instances. It is just that a lot of other plugins can't.
I don't know that plugin myself, so I cannot help here without diving into the code myself.
With one instance I had the same result. It looks to me as if the data can no longer be decrypted by the APP. My device is version V4. Possibly. something has changed in the data and would have to be adapted by the developer. How to contact the developer?
I don't have such a device, nor am I the developer of that plugin.
So I don't think I can be of much help, especially since I don't have something to test with.
Users browsing this forum: No registered users and 29 guests
