Hardware Support Request
jay_s_uk
#1 Post by jay_s_uk » 31 Dec 2015, 02:46
Would it be possible to support the HC-SR501 PIR motion sensor and the INA219 DC Current sensor boards please?
Jay
costo
Re: Hardware Support Request
#2 Post by costo » 31 Dec 2015, 12:10
The HC-SR501 PIR motion sensor is already supported because it actually works like a switch.
The I2C INA219 board would be usefull to measure DC-currents. I support the request.
jay_s_uk
#3 Post by jay_s_uk » 31 Dec 2015, 12:57
costo wrote:The HC-SR501 PIR motion sensor is already supported because it actually works like a switch.
Thanks for letting me know about the HC-SR501. Might be handy to add it to the wiki?
I'm planning on using the INA219 board to know when my milights are actually on as they don't provide feedback.
Jay
DeNB3rt
#4 Post by DeNB3rt » 02 Jan 2016, 00:30
found out that the HC-SR501 is not that stable if used on 3.3V (I think it's restarting each 10sec).
Working well if VCC is getting 5V.
kr0815
#5 Post by kr0815 » 02 Jan 2016, 10:38
The HC-SR501 needs 5Volt, as there is a regulator on board
But you could connect 3.3V after this regulator, then it works
Another problem i realized:
If you put both the HC-SR501 and the ESP in an enclosure where they sit behind each other, you get distortions,, it won´t work
Martinus
#6 Post by Martinus » 02 Jan 2016, 18:06
jay_s_uk wrote:Hello,
Jay
I've ordered one of those INA219 boards from China. Will see what we can do when it arrives...
jay_s_uk
#7 Post by jay_s_uk » 03 Jan 2016, 18:33
Jay
Thank you. Mine comes next week.
Looking forward to playing with it
jay_s_uk
#8 Post by jay_s_uk » 16 Jan 2016, 11:11
@Martinus Got my INA219 in the post if theres anything you want me to do with it whilst waiting for yours?
Martinus
#9 Post by Martinus » 16 Jan 2016, 11:23
You could download R66 from github, it has the first INA219 plugin release:
I only have a small LED attached to 5 volts USB power, so the current reading is not very impressive...
But it seems to work.
jay_s_uk
#10 Post by jay_s_uk » 28 Jan 2016, 14:23
Have tried it with my LED strips and it all works fine.
Thanks again
Edit****
I had to change the address in the plugin as it was conflicting with another device.
The INA219 has 4 different available addresses, 40, 41, 44 and 45.
Would it be possible to add this to the devices page? That way I can use the OTA function without having to edit the file before hand.
