The uptime is shown in the web interface as follows:
0 days 19 hours 50 minutes
But if I would like to display the uptime on a display using "Uptime: %uptime%min" then it shows only in minutes.
So how to display the uptime on a display with days, hours and minutes?
(If it is too long it also could be shown like 0d 19h 50m)
Thanks and best regards,
Chris
How to output 'uptime' in days, hours and minutes?
Re: How to output 'uptime' in days, hours and minutes?
Hi danmero,
Yes I did, but I only found: %uptime% -> Uptime in minutes
I'm searching for a solution for uptime like this: 0d 19h 50m
Thank you and best regards,
Chris
Chris
Maybe
%c_m2dhm%(%uptime%)
Look at formula section.
But in my opinion, there is an error with 'missing' target-minutes. The formula for 'day-hour' and for 'day-hour-minutes' in the wiki syntax, are the same
%c_m2dhm%(%uptime%)
Fixed, thanks!!
Thanks a lot, this works:
%c_m2dhm%(%uptime%)
Just another small question:
Is it possible to change the display from "0d19h40m" to "0d 19h 40m" (added a space between the single values)
Thanks a lot an best regards,
Chris
%c_m2dhm%(%uptime%)
Chris
That's something that needs to be done in the source. Add a feature request on GitHub.
Users browsing this forum: Ahrefs [Bot] and 44 guests
