GIT version: mega-20180515
Wemos D1 Mini (v1 clone)
Wemos SHT30 (v1 clone) (temp/Humid) - Interval 60 sec
Wemos Switch (v1 clone) GPIO - 0
OLED 1306 - Display Timeout 10 sec, Interval 60 sec
Controller EMONCMS - not enabled
What does the OLED 1306 Interval actually control?
Wemos Switch (v1 clone) appears to be a momentary switch that connects GPIO 0 to ground. Is this the correct method of using the Display Button?
There seemed to be no information in the Wiki regarding this.
I have found if both intervals are set at 60 seconds it works fine. Other combinations can lead to data not showing, only "ESPEasy" shows. What is the correct method to be used?
OLED 1306 & Display Button - Interval
Re: OLED 1306 & Display Button - Interval
The interval (on any Plugin page) describes the time between updates of that plugin.
For example the OLED Framed plugin shows a subsequent number of pages (depending on settings) and those page-switches will happen after <interval> seconds.
Thank you.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 94 guests
