ev1527 on and off commands
cobradevil
#1 Post by cobradevil » 28 May 2018, 17:30
Hi all,
i have bought a switch from aliexpress with the ev1527 chip in it.
The device gets recognized in rflink and i can control it.
The problem seems that i can only send a toggle command and not a specific on or off signal e.g.:
If the switch is off and i send the off command it will turn on, is this normal for this chip or should i be able to send the off command anyway and it should stay off?
I hope i made myself clear.
Best regards,
William
Stuntteam
Site Beheer
Re: ev1527 on and off commands
#2 Post by Stuntteam » 28 May 2018, 17:40
This is not really useful for home automation systems since you will never know what state the device is in.
There are plenty of others that have proper distinctive ON and OFF commands.
You should probably tell others what set it is so that people can stay away from it.
cobradevil
#3 Post by cobradevil » 30 May 2018, 06:54
Thank you for your answer.
I already thought so.
Now i have ordered the sonoff t1 eu version.
To see if that one works ok.
Best regards,
William
